Are the ST rear discs the same as the Advance track? I'd like to upgrade the fronts & rears to SVT, but am still wondering what all would be needed. I'll be putting my SVT Hawk HPS pads on the calipers front & rear probably this weekend, so will know for sure if they are a direct fit. I've read and searched, and found conflicting info. So since the ST lower ball joint is different on the knuckles than the SVT's, does that then mean you'll still need an SVT knuckle to fit the larger SVT discs on the ST? If not, then all I'd need for the front conversion, if the ST calipers are the same as the SVT calipers, would be the SVT caliper mounting bracket & SVT rotor?
Edit: I may just have to be the guinea pig, buy all the SVT front & rear stuff, and see what needs to be used & what doesn't. Oh well, someone's gotta be the first
