Massive Speed System
Results 1 to 12 of 12
    May 2003
    ohio, cincinnati
    120
    Default IMPORTANT: Where can I find a 7mm allen wrench!!!!!!!!
    Who do I have to kill to get a 7mm allen wrench. I've been to several Autozones and no one makes a 7mm. The sets switch from 5mm to 6mm to 8mm completely skipping 7mm. I understand that it might not be used often but they could at least give you one when you buy a pack of 9 or 13. I need to get one tonite so I can finish changing my pads and go to work tommorow. Any help would be appriciated.
  2. #2
    Educating Mazda Owners One Thread at a Time Nliiitend1's Avatar
    Sep 2001
    60607
    4,717
    Default Re: IMPORTANT: Where can I find a 7mm allen wrench!!!!!!!!
    look for a 7mm brake caliper socket. It's basically a socket that has a small hex head on the end. I got mine at AutoZone.
  3. #3
    May 2003
    ohio, cincinnati
    120
    Did you buy it seprate and under that name? I just got back from Autozone and the guy made it sound like a 7mm was rare as a diamond he told me "I must be working on something strange, and I should go to Sears." And I asked the other Autozone if they sold Allen keys seperate and he said no.
    I wish I had your Autozone around here. I guess I'm screwed, I've been tryig to change these pads all day, and it's been one thing after another.I'm just going to put they damn wheel back on and I'll ride the pads until they spit sparks of the rotor.
  4. #4
    Egz
    Egz is online now
    Inheritly Sinister
    Nov 2000
    Tappahannock, VA
    12,830
    Did you try Sears?
  5. #5
    Oct 2001
    Home
    4,983
    If you take a close look at the bolt head and if its like mine, it will also take a Torx. That's what I use to change my brakes. Can't remember the size but if you pick up a set, there should be one that works. I have a cheap Stanley set I picked up at Walmart.
  6. #6
    Nov 2001
    Chicago
    2,367
    7mm is a strange beast. some people here have found them in sets, i got mine at an industrial tool supply house (and even then i had to point out in the catalog that it actually existed, the grizzled old guy at the counter didn't believe they existed)
  7. #7
    Jan 2002
    Cincinnati Ohio USA
    714
    Dude I would lend you mine, but with the shift I work I couldn't get it to you till Wednesday. If you wait till then I'll help you put them on. If you do get to them yourself remember this, do one side at a time. Makes for a nice visual aid.
  8. #8
    Super Moderators
    Aug 2000
    Kirkland, WA, USA
    5,391
    I didn't have any trouble finding one?
    http://www.sears.com/sr/javasr/produ...;bidsite=CRAFT
    In case the link doesn't work:
    Craftsman 7mm Hex Key
    7mm hex key.
    Sears item #00946795000
    Mfr. model #46795
    Maybe you need to ask for a "Hex Key" instead of an "Allen Wrench"? Must be a name brand vs. generic name thing.
  9. #9
    [FJ] Addict
    Apr 2002
    19,248
    my hundred piece craftsman tool kit had it come with it.
  10. #10
    Super Moderators
    Sep 2003
    Harrington Park, New Jersey
    12,231
    a 7mm hex socket is what you need b/c you gota torque it down.
    We spent like a half hour looking through the garage tool chests to find a damn 7mm hex socket.
    I had the allen key, but not the socket.
  11. #11
    Jun 2003
    2,838
    I used a 40-something Torx to take the caliper off because I didn't have a 7mm
  12. #12
    Oct 2001
    Home
    4,983
    Yea, upon close inspection of the bolt, you can tell that it is designed to take either a Torx or a hex.
