Grassroots Motorsports
Sponsored by: The Tire Rack
Old 06-28-2005, 06:37 PM   #1
knarf
Default drum to disc conversion??
How big of a pain in the ass will this be to undertake? And any suggestions for the best and cheapest kits? Thanks for the your input.
knarf is offline   Reply With Quote
Old 06-28-2005, 06:41 PM   #2
DisrupTer911
Default Re: drum to disc conversion??
not its a terrible difficult conversion
it just costs alot assuming you don't have a donor car to get all the parts off of.
however, if u've got all the parts from a junked or wrecked car...it becomes a thousand times cheaper and easier.
DisrupTer911 is offline   Reply With Quote
Old 06-28-2005, 07:01 PM   #3
knarf
alright thanks for the tip. but when i find one what will i all need to salvage of the donor focus?
Old 06-28-2005, 07:09 PM   #4
Tekin112
spindles, hubs (connected to spindel if from junk yard), brake lines, parking brake cables, disc, caliper brakets, calipers.
salvage yard collection
Tekin112 is offline   Reply With Quote
Old 06-28-2005, 08:23 PM   #5
ElPogoLoco
You can also contact Jeremy at Focussalvage.com and he may be able to help you out.
ElPogoLoco is offline   Reply With Quote
Old 06-28-2005, 08:31 PM   #6
knarf
hey thanks everyone for you help, pogologo and all. i'm in the process of finding the needed parts.
Old 06-28-2005, 08:50 PM   #7
ILfocus
if you have every thing but the pasg rear spindle assyl and hub? can you use the rear assy from the zx3? say if i had a donor svt?
ILfocus is offline   Reply With Quote
Old 06-28-2005, 09:32 PM   #8
Tekin112
This might help. And no you cant use the rear hub assembly from the zx3. the zx3 has drum brakes, and uses a differetn hub.
Old 06-28-2005, 09:45 PM   #9
knarf
so once i find my parts what am i in for? any approximate completion times or if any one has conquered this task in the past. thanks
Old 06-28-2005, 09:47 PM   #10
Tekin112
rear disc brake conversion with a lift took me about an hour.
Old 06-28-2005, 09:57 PM   #11
ILfocus
man come over and we will do it together!
Old 06-28-2005, 10:34 PM   #12
knarf
hey pogologo, thanks for the tip on the focussalvage.com but i got a quote from jermey for $600. I can get a new non-salvaged kit for only another $100. So I'll pass on the salvaged rear end. Thought he'd be cheaper than that. Junk yards here I come.
Old 06-28-2005, 10:39 PM   #13
ILfocus
hey man i live in godfrey and i am going to be doing this as soon as the car gets out of the shop, i got all the parts on hand right now.
Old 06-28-2005, 10:43 PM   #14
knarf
Well I'd love to come up and help but I'm not that lucky to have the parts yet. But I would be up for lending a hand and learning.
Old 06-28-2005, 10:53 PM   #15
ILfocus
i will be hosting a bbq when i do it, because the engine will be in and the paint work is already done!
we will learn on my car, win win fo ryou
Old 06-28-2005, 11:45 PM   #16
ouikikazz
did you paint the parts or something? why's is all glossy black?
ouikikazz is offline   Reply With Quote
Old 06-29-2005, 12:07 AM   #17
knarf
so where did you score all your parts? donor focus or wrecked or salvage yard or what? i need some help.
Old 06-29-2005, 01:18 AM   #18
BLrDFCS07
You don't need a new master cylinder? I thought that with disc/drum set ups, because on discs the pads are always slightly touching the rotor that the rear drums need to be engaged a split second before the discs because the pads have farther to travel, thus needing a master cylinder set up thats different? That was just my understanding, could be outdated or N/A for this, I dn.
BLrDFCS07 is offline   Reply With Quote
Old 06-29-2005, 06:22 AM   #19
Tekin112
i powder coated them all, and i picked up a totaled svt focus from a yard for nex to nothing.
Old 06-29-2005, 09:53 AM   #20
sleeperlove
you forgot the HUGE blower label tekin
sleeperlove is offline   Reply With Quote
Old 06-29-2005, 11:49 AM   #21
c4uldr0n
wow, that's a good quick time!
c4uldr0n is offline   Reply With Quote
Old 06-29-2005, 12:24 PM   #22
ouikikazz
how much did it cost to powder coat them?
