Sponsored by: The Tire Rack
Old 08-20-2005, 01:14 AM   #1
SVTZETEC03
Default SVT Tire question, Will going from 45 to 50 be ok?
I am curious if this will cause any sort of rubbing by increasing the height of the wheel, Curious if anyone knows?
My reasning is because I just put an RS bumper on and its sitting rather low and it can scrap, and a solution would be to increase the sidewall to raise the height(and it will throw off teh speedo a little too).
Anyone who knows I would greatly appreciate your time.
SVTZETEC03 is offline   Reply With Quote
Old 08-20-2005, 01:19 AM   #2
Ataru
Sonic Watch 09 in Effect
Location: Where the winds come sweeping down the plains
Default Re: SVT Tire question, Will going from 45 to 50 be ok?
You will probably rub.
You would be going from a tire with a 24.6" diameter to a 25.5" diameter. Of coure, I bet you could think of it similar to lowering your car an inch as far as clearances are concerned.
But since that tire is 1" in diameter bigger, that will only get you about 1/2" more ride height. I don't think it would be worth it.
Ataru is offline   Reply With Quote
Old 08-20-2005, 01:21 AM   #3
Z63R
The Magnificent Mr. Z
Might not be worth the overall effective gearing change (the car will not accelerate as crisply) for the very minor increase in ride height.
Z63R is offline   Reply With Quote
Old 08-20-2005, 01:24 AM   #4
SVTZETEC03
Im trying to figure out how to keep from ruining the bumper, i thought maybe a skidplate, but I have not been able to find one...(i cant really add a lip because its already low enough to hit driveway's(giong up the bump portion).
Old 08-20-2005, 01:25 AM   #5
Ataru
Just be REALLY careful.....
Old 08-20-2005, 11:41 AM   #6
RogeratTireRack
You would be increasing your overall diameter by .9", so there is high probability you will rub!
RogeratTireRack is offline   Reply With Quote
