Sponsored by: The Tire Rack
Old 09-01-2005, 07:52 PM   #1
gotboost20051
Default rims
will a will with a 38MM offset fit on the focus its a 02 Se sedan
gotboost20051 is offline   Reply With Quote
Old 09-01-2005, 08:11 PM   #2
Reza
Formerly focus_wrc
Default Re: rims
i wouldnt go more than 42 i think you can get away with 40 but not 38
good luck
Reza is offline   Reply With Quote
Old 09-01-2005, 09:16 PM   #3
gotboost20051
Default Re: rims
could i not jsut use spacers
Old 09-01-2005, 11:36 PM   #4
pitchblack23
Default Re: rims
Spacers would make the problem worse. In effect, they subtract from the offset, not add to it.
pitchblack23 is offline   Reply With Quote
Old 09-01-2005, 11:49 PM   #5
gotboost20051
Default Re: rims
so will a 38mm off set not work at all and if not why
Old 09-02-2005, 12:13 AM   #6
DisrupTer911
Default Re: rims
its going to stick out past your fenders and your wheel lugs arn't going to be long enough to have adequate threads for the lug to catch on.
I wouldn't suggest it for safety's sake. Granted oyu could just get longer studs, but you'll be throwing off the handling characteristics of the car by pushing the wheel so far out
DisrupTer911 is offline   Reply With Quote
Old 09-02-2005, 12:22 AM   #7
gotboost20051
Default Re: rims
but see what i dont get it how come a 40mm would work but a 38 wont
Old 09-02-2005, 10:08 AM   #8
JJFocus
Default Re: rims
Nobody said yes 40 would work. It might with the right tire choice but most likely will rub.
38 is only going to make that worse, pushing the wheel further out.
Stay between 42 and 49 and you should be fine.
J.
JJFocus is offline   Reply With Quote
Old 09-02-2005, 04:06 PM   #9
eurozx3
Default Re: rims
Yes they will "work" but I guess you could also get a set of 33" mud boggers on there if you want too. It is just not an ideal setup.
eurozx3 is offline   Reply With Quote
