Central Florida Motorsports
Page 1 of 2 12 LastLast
Results 1 to 15 of 29
    Apr 2001
    Pittsburgh, PA
    912
    Default Wheel frozen on hub - how do you get them off?
    I've been soaking it in PB Blaster for days and beating it with a mallet.. Even broke one of the strut tower bolts off doing it.. sweet!
    What do you guys do to get stuck wheels off?
    Also, what do you do to them before you put them back on to prevent it from happening?
  2. #2
    Apr 2003
    Park City, UT
    597
    Default Re: Wheel frozen on hub - how do you get them off?
    hmmm... you've tried the normal methods.. Soak w/ PB blaster, bang the bell out of it from behind.
    Is it on a lift? or just jack stands? I've layed underneath before and kicked the hell out of it before. On a lift, a good heavy mallot shout get it off since you have the room to swing. Jack stands are a pain, I can never get enough of a swing laying on my side/back.
    A buddy w/ his VW loosened his lug nuts slightly, drove around the block once slowly and that broke his loose.. (try at your own risk!!!!!!!!!)
    when you put it back on, grease the hubcentric ring (and take your wheels off more often )
    2003 2.3L ZX3 5sp. FS Stage 1 and some other stuff(226whp 192tq)
  3. #3
    Apr 2001
    Pittsburgh, PA
    912
    It's on jackstands, and doesn't have a passenger side halfshaft or knuckle, so driving it around right now isn't an option, or I would do that.
    Maybe I'll try to find a bigger mallet.
    Thanks for the reply!
  4. #4
    Official [FJ] Distinguished Advisor Z63R's Avatar
    May 2004
    TEAM AllCal
    19,806
    Like mosaholic2 suggested, kick it or try a 6' 2 X 4... wedge it wherever (at your own risk, of course...).
    As for preventing stuck wheels (the stock aluminum ZX and SVT wheels are a tight fit on the hub's register), I take one of those 99¢ brass bristle, wooden handle wire brushes and brush the rust off of the hub and brush the aluminum corrosion out of the wheel's hub register bore. Follow that brushing with a thin coat of teh paste lo0b of your choice.
    "Wine tasting isn't bad, but given the choice, I'd rather drink left-over beer and replace brake pads." - OmniFocus
    2.3 Duratec ZX3 + some bits
  5. #5
    Oct 2002
    San Jose, CA
    1,383
    I used to lay a long board under the car with one end pushing against the rear side of the stuck wheel and then beat the hell out of the board with a hand sledge. It takes some time but I strongly discourage you from laying under the car, kicking the wheel while it is on jack stands.
    2002 Focus SVT / Mildly Solo II DSP Prepped - Sold to Smike
    1999 BMW E36 M3 - Obnoxious
    2008 VW GTI - The girlfriend's car
    Dave
    Applications Development Engineer at KLA-Tencor
    Pattern Wafer Inspection - Dark Field
  6. #6
    Nov 2006
    Erie, PA
    882
    If its frozen.....why not put a heater by it? But yea I always put a tiny amount of axel grease on the hub, havnt had one stick yet.
  7. #7
    Dec 2002
    Rhea County-get it? RHEAcer...
    4,109
    um. How about putting a 2x4 under the tire with no lugs, and let it down. Weight of car should bust loose.
    wipe both hub and wheel surface with some WD 40 or bearing grease. Just enough to leave a sheen.
    "If you come to a fork in the road, take it."
    Yogi Berra
    www.rheacermotorsports.com
    JohnB, I have your hat.
  8. #8
    May 2004
    Whittaker, MI
    4,105
    I run into this problem almost everyday at work. Aluminum wheels frozen to steel hubs on cars. We have a big rubber mallet that we use to solve this problem. Personally, on my car, I had this problem the first time I took my wheels off the car, I used a wire wheel on a drill to get rid of all the rust and corrosion on the hub, then applied a thin layer of white lithium grease to the flat surfaces that meet when the wheel is on the car. Haven't had a problem since.
    2006 Ford F-150 XL
    2005 Suzuki SV650N
    Hopefully, a 2011 Focus or Fiesta when they hit the market
  9. #9
    Aug 2006
    Florida
    567
    I dothe same thing where I work you could also use some Nickle anti-seize it will last fore ever to where White Lithium Grease will eventually dry up from the heat of the brakes.
  10. #10
    May 2004
    Whittaker, MI
    4,105
    You think I spend that extra time and shop supplies on customer cars that I have to get out as quick as possible? No. Only thing I do if i have to is take a wire brush to the hubs to get the crap off them. I even asked the boss if we did that, he thought I was joking.
    2006 Ford F-150 XL
    2005 Suzuki SV650N
  11. #11
    RECORD PROFITS ZX3autoxtasy's Avatar
    Jul 2004
    atlanta
    5,297
    Get under the car.
    Make sure it's well supported by jackstands, etc.
    And kick the **** out of the wheel with both feet.
    Also, maybe have somebody to catch the wheel too. Or, steer clear of anything near the wheel.
    2011 Relfex Silver VW Golf 2.5L 5-Cylinder: I need some fancy Mercedes wheels for this thing...
    2004 Pitch Black 5spd 2.0L(Z) ZX3: Totalled 4/26/2011 :(
    Stuff left to sell off it: FocusSport Cool-Flo intake, H&R Rear Swaybar, Thule OEM Roof Rack w/ Fairing, Camber Bolts, etc.
    2008 Specialized Tarmac. 2010 Giant Anthem X2. Trek 1500. Fuji hipster bike. Boom.
  12. #12
    HELLAFRUSH thefrush's Avatar
    Jul 2004
    Sacramento, CA
    9,746
    Blow dryer?
    ((. When someone asks me the cause of a minor injury, like a scrape on my leg,
    .)) I like to tell them something extreme happened. Like I got attacked by a bear.
    ((. They're way more impressed than if I was missing an arm or something.
    .)) Obviously that bear didn't have crap on me.
  13. #13
    Jul 2004
    atlanta
    5,297
    Quote Originally Posted by thefrush
    Blow dryer?
    Wait, correct me if I'm being stupid.
    ... I don't think the wheel is physically frozen on the hub, just rust and stuff keeping it stuck on.
    ...or am I an idiot and will a blowdryer get a rusted connection off?
  14. #14
    Dec 2002
    4,109
    I'm hoping just rust.
    But a torch to heat up the wheel might work too. Not sure a hair blower will get hot enough. Y'all scare me with all this laying under cars and kicking stuff. Just let the thing down with no lugs. Just be sure no one is laying under it. ;^)
    Yogi Berra
  15. #15
    May 2004
    TEAM AllCal
    19,806
    ZX3autoxtasy
    Get under the car.
    And kick the **** out of the wheel with both feet..
    For the love of God...
