Tire Rack
Page 1 of 2 12 LastLast
Results 1 to 15 of 24
    DoubleStuf™
    Jan 2005
    Parkville, MD
    3,716
    Default Any problems with Autozone's Duralast rotors?
    Is there any reason to question the quality of Autozone's Duralast brand rotors? I can get all 4 corners in SVT size for < $130 total. No sponsor I've seen can come close to that price.
    Or what about Pep Boys? I can get the rears from Pep Boys for $12 a piece!! THat would be $87 for the whole set!!
    Thanks,
    Jason
    Now being tuned by the world class, fastest of the fast, baddest of the bad-ass worker of hokus-pokus on the focus! Give it up for Mr. Randy Robles of FSWerks!!
    Torsen, 4.06,
    Fidanza FW, Luk ProGold clutch, Cosworth IM, Stg 2 Crane cams, Eagle ConRods, 12.5:1cr 88mm Supertech pistons, CFM Adj. cam gears, Cosworth CAI, Draxas & Trubendz exhaust, SVT Brakes, ST200 Rims, Koni Sports, Apex springs, poly FLCA & dog-bone bushings, Progress 22mm RSB, TriAx/F STS, XCal2- *Now with more ProRacer!*
  2. #2
    Mar 2005
    St. Louis, MO
    1,166
    Default Re: Any problems with Autozone's Duralast rotors?
    Rotors are rotors.
    I usually buy the cheap ones vs. the blintastic-pimp ones since they are a wear item and get replaced on a regular basis.
  3. #3
    Apr 2007
    5
    Iam Having The Duralast Rotors Put On Today With Hawk Street Pads. The Stock Rotors Are Crap. They Lasted Only 30,000 Miles And Can Not Be Turned Down Due To They Will Then Be Thinner Than Specs Allow. The Rotors Cost 120$ From Autozone For All Four. The Pads Came From The Tire Rack For Around 150$ Total. I Will Let You Know How They Work Out. Will Pick Up Car This Afternoon.
  4. #4
    Aug 2004
    Union, MO
    8,101
    Quote Originally Posted by carlfreddy
    Rotors are rotors.
    This. They're just cast-iron circles. The only reason not to go cheap is if you go so cheap that they're damaged or oval or something.
    '04 PZEV ZX3
    Well done, android. The enrichment center reminds you that Android Hell is a real place where you will be sent at the first sign of defiance.
  5. #5
    Apr 2007
    5
    Picked Up The Svt Today. Had Hawk Streetpads And Duralast Rotors Installed At All Four Corners. Terrific Braking! The Car Never Braked This Good With The Stock Pads And Rotors. Iam Very Happy. Smooth, Strong Braking. No Squeaking. Granted, They Have Only Been On The Car One Day, So We Shall See In The Long Run. But For Now, I Can Not Complain About The Duralast Rotors. Considering I Picked Up All Four Rotors For 120$. Much Better Than Stock And The Brembos And Pbr Australias Are Way More Money Than I Want To Pay, Upwards Of 175$ Per Rotor For The Pbr's.
  6. #6
    Jul 2006
    Largo, Fl.
    911
    sounds good, enjoy them.
    2005 ZX4 ST 2.3
  7. #7
    [FJ] Addict brads03zx3's Avatar
    Sep 2004
    Traffic
    11,368
    I have no experience with Autozone rotors, but know somebody that warped them after 1 autox. All metals are NOT created equal, I am not saying these are terrible, but just keep that in mind.
    Mountain Tested----'03 zetec
    ZX3 vs MNTN - 15-2 & ZX3 vs TRACK - 23/1 JCM Racing #88
    Vacuum Vulture Racing - We Make You Less Powerless
    Quote Originally Posted by norcalfocus01 View Post
    ...too short to be a dick.
  8. #8
    Official [FJ] Distinguished Advisor Z63R's Avatar
    May 2004
    TEAM AllCal
    19,806
    I agree with Brad that all brake rotors are not created equal... you get what you pay for to some degree. Though I have no research at hand (but I will get it if necessary) to back this up, it stands to reason that a $12 rotor might not be as much of a quality product as a $50 rotor. Sure, some of the difference is markup, but consider the cost of manufacture, the cost of material and then labor costs. My main concern is materials quality and manufacturing standards.
    For example, a rotor made in China may not be as well-made as a rotor made by Brembo's Original Equipment Service Replacement division; the Brembo "blank" is visibly superior in production craftsmanship and materials to an inexpensive, "offshore" casting from Asia.
    When the time comes for replacement rotors for my ZX3 Focus's new SVT brakes, I will most definately use the FoMoCo Part #'s 2M5Z-1125-AA Front / 2M5Z-2C026-AA Rear rotors made in Italy.
    Oh, here's another, interesting facti0d: The "Warped" Brake Disc and Other Myths of the Braking System
    "Wine tasting isn't bad, but given the choice, I'd rather drink left-over beer and replace brake pads." - OmniFocus
    2.3 Duratec ZX3 + some bits
  9. #9
    Sep 2006
    angola, NY
    1,551
    Quote Originally Posted by venomrogue
    I use Duralast rotors on my ZX3..12 bucks a piece, and I change them every time I do a brake job...about every 6-9 months.
    ouch!
    2006 zx3, 2.0 PZEV. Toreador red
    Body Mods: Roush front fascia, HIDs (6k), 5% Tint, Blue turns, Silverstar fogs, painted headlights, BOSCH wipers.
    Performance Mods: MBRP exhust, F2 CAI, F2 Header, Cosworth Cams, CFM 65mm TB, FC short throw, Steeda MIL eliminator, energy dogbone inserts, SVT 5 spoke wheels w/ Hankook K106 rubber, SVT dampers and FRPP 1 1/2 drop springs, Bix RSB retrofit, Eibach anti-roll kit(22mm front/25mm rear), slotted rotors and Hawk HPS pads, XCAL2 by FocusSport.
  10. #10
    No Cause For Alarm MichaelXi's Avatar
    Sep 2001
    Venus Via Knoxville, TN
    17,312
    Quote Originally Posted by whyme
    ouch!
    Ouch?
    Pads SHOULD potentially last longer, but he didn't mention mileage.
    If they are $12 apiece, where's the "Ouch" when a brake job is SO Easy on a Focus?
  11. #11
    Jan 2007
    CA
    343
    I think the "ouch" is generated by SVT owners (aren't they about 5x as expensive?).
    Even paranoids have enemies.
  12. #12
    [FJ] Specialist Johnny_P's Avatar
    Nov 2004
    Philly, PA
    5,514
    if you get them, be sure to inspect them pretty good.... when we did my buddy's maxima with the $12 specials we found leftover sand casting inside the cooling vanes of the rotor. we blasted it out with a garden hose and a screwdriver
    so don't just "put them on".... look em over
    '12 Trek X-caliber // '11 Cervélo R3
    2010 VW GTI
    2000 Focus SE (sold)
  13. #13
    Oct 2003
    San Diego
    1,276
    Most of the Duralasts have a decent warranty. They are made in china, but are so cheap that it makes sense to replace them everytime you change your pads. I second inspecting everything before you buy it...I work at Autozone, and never sell anything without looking it over...never know what you are going to find .
    "Guns don't kill people, physics does!"
    "take a can of WD-40 and spray a SMALL amount ONLY A SMALL amount on the pads and bam the noise is gone and the breaks work just like new..."
  14. #14
    Formerly focus_wrc Reza's Avatar
    Aug 2004
    Los Angeles
    7,377
    Quote Originally Posted by Z63R
    x100000
  15. #15
    Aug 2006
    ON, Canada
    258
    Gotta love Carrol Smith, I am upset that I never took the time to talk to him when I had a chance. His writing is so easy to read and with the experience that he has, what he suggests can be considered gospel.
    As for the Rotors, another down side of the budget rotors is the corrosion resistance. They dont have the zinc plating to protect them, which is where a huge cost comes from.
    2004 SVTF Euro Black #485 that has now joined the 100k club
