Sponsored by: The Tire Rack
Old 03-31-2007, 10:42 AM   #1
whyme
Default grinding sound, tires??
i put my svt wheels on today an imeadiatly noticed a grinding like sound while brakeing, the tires are the ones that where on the rims when i got them (used) and the tires have bad feathering. the car made no noise before, nothing seems to be rubbing, and the rims are down tight.
just whant to check to see if this is normal (kinda) and im ordering new tires today i just had to get the winter tires off.
2006 zx3, 2.0 PZEV. Toreador red
Body Mods: Roush front fascia, HIDs (6k), 5% Tint, Blue turns, Silverstar fogs, painted headlights, BOSCH wipers.
Performance Mods: MBRP exhust, F2 CAI, F2 Header, Cosworth Cams, CFM 65mm TB, FC short throw, Steeda MIL eliminator, energy dogbone inserts, SVT 5 spoke wheels w/ Hankook K106 rubber, SVT dampers and FRPP 1 1/2 drop springs, Bix RSB retrofit, Eibach anti-roll kit(22mm front/25mm rear), slotted rotors and Hawk HPS pads, XCAL2 by FocusSport.
whyme is offline   Reply With Quote
Old 03-31-2007, 11:25 PM   #2
2xtremefocus
Default Re: grinding sound, tires??
Grinding while braking doesn't sounds like anything that could possibly be related to the tires.
I'd pull your rims and check your brakes. See if the rotors are scored at all. Maybe something got onto the rotor and the pad caused it to score the rotor.
I've never heard of a noise like this coming from a tire.
2006 & 2007 [FJ] F1 Challenge 3rd Place finisher.
2xtremefocus is offline   Reply With Quote
