Sponsored by: The Tire Rack
Old 10-13-2008, 09:26 AM   #1
redzx300
Default will euro svt's fit around brembo bbk?
Has anyone tried this, and do they fit without a spacer?
thanks
Parts thanks to Steve at MassiveSpeedSystem.com, Tony at Newedgeperformance.com, HondaHunter.
Motor Built By Messer Engines in Springfield, Vt
redzx300 is offline   Reply With Quote
Old 10-13-2008, 10:18 AM   #2
sleeperlove
Default Re: will euro svt's fit around brembo bbk?
They absolutely will NOT fit without a significant spacer.
Member Clintb1321 has used the EAP wheels with the brembo BBK and had to use a pretty big spacer for them to just barely clear.
sleeperlove is online now   Reply With Quote
Old 10-13-2008, 10:26 AM   #3
redzx300
much appreciated for the quick response.
Has anyone tried team dynamics pro race 1s?
Old 10-13-2008, 10:41 AM   #4
brads03zx3
Clint has the larger of the Brembo BBK. CrocTease! and a couple others have the smaller kit. I would imagine the smaller kit would probably need a spacer as well. Those calipers are massive.
Mountain Tested----'03 zetec
DuraMonster---'03 duratec
Old 10-13-2008, 11:44 AM   #5
redzx300
I believe i have the larger of the kits. they are the two piece rotors.
thanks again for reponses.
Old 10-13-2008, 02:07 PM   #6
Z63R
Yes, but only over the large but stock SVT brakes...
Nothing like cad plated steel to impress the ladies." - FocusSportVP
2.3 Duratec ZX3 + some bits + another pic :-)~
Z63R is offline   Reply With Quote
Old 10-13-2008, 08:54 PM   #7
Z63R
^ Talking about their 15-inch wheels, too!
Old 10-13-2008, 09:32 PM   #8
Croc_Tease!
Rota SDR 17x7.5 fit with no spacer over your kit. The EAP's require a 15mm spacer.
TD pro race 1 might fit. You might be able to get measurements from hub center to inner spoke to find out if it will clear. Call a distributor.
EVIL ZX3
Buy my Bilstien PSS9.
Buy my Receiver.
Croc_Tease! is offline   Reply With Quote
Old 10-16-2008, 07:48 PM   #9
thenorm
I bet 17" TD PR1 will fit. they have a better shape than rota's to clear calipers (case in point, 15" PR1's will clear SVT brake,s but rotas will not)
thenorm is offline   Reply With Quote
Old 10-17-2008, 12:38 PM   #10
sleeperlove
There is no 15 inch SDR and I doubt the the PR1 spoke is "better than the SDR's as far as brake clearance goes. The SDR is fantastic as far as break clearence it has a TON of room. Also its PROVEN that the SDR clears just fine, not so with the PR1s as far as I know.
Also 15 inch slipstreams will clear the SVT brakes, so I am not sure where you are getting your info.
Old 10-21-2008, 11:12 AM   #11
cnegron
Which rims are you guys typically using with BBK, I've had a horrible time trying to find something that fits and looks OEM. Do the OZ superturismos fit? I have the saleen brembo kit.
cnegron is offline   Reply With Quote
Old 10-21-2008, 11:41 PM   #12
93SHO03SVT
I also have the 328mm brembo gt kit i currently have 18x7 oz supertorismos that fit with a 5mm spacer.......i am haveing a hell of a time finding some 17's (for auto-x) that will fit over the brakes what is the offset on the rota sdr 17x7.5? and where can i get them?
93SHO03SVT is offline   Reply With Quote
Old 10-21-2008, 11:47 PM   #13
Croc_Tease!
45mm, and good luck finding them. They aren't being made anymore (iirc) so best try and get a used set on here.
EVIL ZX3
Buy my Receiver.
Old 10-22-2008, 12:08 AM   #14
sleeperlove
I will have a set of SDRs for sale very shortly. Mine are one of the custom order sets for the focus so no hub bore is correct negating the need for a hub ring like most wheels.
Old 10-22-2008, 12:24 AM   #15
ClintB1321
^ill take them off your hands jkjk, i dont need a third set
Liquid gray 05 ZX3-2.3 build in the works:)
Sonic blue 02 SVT-RIP
Classic Red 97 Miata- saving for LS1 awesome:)
Boost Camel Racing...cause the b**ches love BOV's;)
JCM Racing #310
ClintB1321 is online now   Reply With Quote
Old 10-25-2008, 06:08 AM   #16
cnegron
What offset are the Superturismos?
Old 10-25-2008, 02:36 PM   #17
sydneysky84
Newbie
lol
sydneysky84 is offline   Reply With Quote
