Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > The Tire Rack Tires/Wheels/Brakes Forum
Sponsored by: The Tire Rack
Old 03-05-2008, 06:04 AM   #1 (permalink)
Default stock 16in wheels vs svt brakes
do they fit. might need to use stock 16s here during a budget crunch and i'm sick of dealin w/the rear drums. just wanted to know. i've heard that stock 15 (zts) wheels fit over the rear discs (the major issue), but naturally dont over the fronts.
thanks for help
R
it amazes how long i've been here...
UltegraSTI is offline
Old 03-05-2008, 07:31 AM   #2 (permalink)
Egz
Moderwhiner
Egz's Avatar
Default Re: stock 16in wheels vs svt brakes
I've never heard of any issues with 16s on SVT brakes.
Egz is offline
Old 03-06-2008, 02:12 PM   #3 (permalink)
Administrator
focusownerskid's Avatar
2.3 L1QUID ZX3
///type dRew
focusownerskid is online now
Old 03-06-2008, 02:52 PM   #4 (permalink)
CSVT wheels will fit as well.
“Empty your mind, be formless, shapeless - like water. Now you put water into a cup, it becomes the cup, you put water into a bottle, it becomes the bottle, you put it in a teapot, it becomes the teapot. Now water can flow or it can crash. Be water, my friend.” - Bruce Lee
sleeperlove is online now
Old 03-07-2008, 03:47 AM   #5 (permalink)
Yes they do, there a bit tight. The dowl in the picture is half a inch.
Front
Anyone can go fast in a straight line.
2002 SVT Pitch Black #3633 ~ Built 7/2002
Tuned by Focus Sport/SCT ~ 17x7 White OZ Superleggera with BFG KDW 2's, street ~ 17x7 Dark Argent OZ Superleggera with Falken RT-615, track ~ Steeda Short Throw Shifter ~ VF-Engineering Rear Engine Mount ~ H&R Coilovers ~ Graphics by WebXtremes
McSVT is online now
Old 03-07-2008, 06:45 AM   #6 (permalink)
hey thx for takin the time on that man, really appreciate it.
R
Old 06-26-2009, 05:43 PM   #7 (permalink)
Pulling this from the dead since this has a useful picture....
With the SVT brakes and stock 16" rim, does anyone track this setup? The half inch gap concerns me with 30 minute track sessions in 100+ degree weather down here would it create excessive fading and wear and lower effectiveness?
It will probably a good 6 months until I could pony up for 17s...
blueroach is offline
Old 06-26-2009, 07:01 PM   #8 (permalink)
Michael's Eye... Get It?
MichaelXi's Avatar
I don't believe it would cause significantly more heat buildup, BUT, if there is LOTS of HEAVY Braking on the course, you want as little heat as possible. I have screwed up some front wheel bearings at the track, and when I opened them up to replace them, it was obvious that the bearing grease had been ruined. I had had a TINY Bit of fade for about a quarter lap at VIR Full, and I was on Hawk HP+ pads at that particular session. Other than that brief moment, the brakes were great all weekend. (Standard brakes... Non-SVT)
It seemed that the wheel bearings took as much heat abuse as the brakes.
Granted, there is an issue with the OEM wheel bearing nuts which can contribute to bearing failure due to heavy track use, but I feel fairly confident that my first front wheel bearing failure was ALSO due to heat. The next time I went to the track, I had home-made cooling ducts run from behind the lower grille back to the rotor area. Not the best design, but it was all I could do on a budget. On that weekend I had Carbotech XP-8 (or XP-9? I forget) pads, and I had no problems whatsoever.
MichaelXi is offline
Old 06-26-2009, 09:00 PM   #9 (permalink)
Team Sonic Racing Pit Crew
Phacade's Avatar
16's on the SVTF? Looks and rides great!
2003 EAP SVT "Attila" - ST170 Headlights ■ Hofele grill ■ SAP rear defuser ■ Clear corners ■ Taylor 8.2mm plug wires ■ Saleen/Eibach suspension kit ■ Focus Central short shift ■ Steel Grey Rota Grids ■ Massive front strut bar ■ Euro rear wiper ■ Shorty antenna ■ SVT-logo Redline carpet kit ■ Powdercoated valve cover ■ Billet aluminum fuel door ■ K&N drop-in filter ■ Debadged ■ Euro HVAC ■ ...and then of course me (being a narcissist, I consider this to be the most important mod).
Phacade is offline
Old 06-27-2009, 04:28 AM   #10 (permalink)
age
hi mate. im thinking of doing the same thing but there isnt much room due to a bunch of radiator and other hoses in the way on the right hand side. this might be because we get the euro model in australia so the bumper design might be a bit different. anyway, any chance you could explain what you did or take some photos so i can get a few ideas? thanks alot.
age is offline
Old 06-27-2009, 09:58 PM   #11 (permalink)
One dissadvantage of running stock Focus wheels like I am is that they are only 6" wide. So if you want to run them on track you are limited in tire width. You are better off looking for aftermarket 16" wheels.
McSVT is online now
Old 06-29-2009, 12:46 PM   #12 (permalink)
I agree!!
Old and Busted: 2002 Fully built Powerworks ZX3
New Hotness: 2004 Comp Orange JRSC SVT
As well as TWO 2002 Red SVT's
Parts by Karl @ Massive Speed System (www.massivespeedsystem.com)
Tuning and porting by Mark @ Skidmark Racing (turbof150.com)
venomrogue is offline
Old 06-29-2009, 08:12 PM   #13 (permalink)
brian, you show off
Gone: 2001 Focus LX with a few upgrades
2002 Focus ZX3 w/ custom turbo: parts from Massive and Top Speed, built and tunned by SkidMark Racing
ProjectSedan is offline
Old 07-02-2009, 01:26 AM   #14 (permalink)
thenorm's Avatar
you can also use the porsche cooling fins. I plan to if/when i take back to the track.
http://forums.focaljet.com/road-rall...ing-ducts.html
thenorm is offline
Old 07-02-2009, 10:37 AM   #15 (permalink)
Originally Posted by venomrogue View Post
I agree!!
What 16" wheels are those on your SVT?
JEEPers is offline
Old 07-02-2009, 11:50 AM   #16 (permalink)
dare i ask but what about a 16x8 or 8.5 with the appropriate respective offsets??? i wanna put more rubber down without bulging over my lip like on the stock 17x7s i wanna have 225s that flush right up to the fender...
Originally Posted by Snake Eyes XIII
So the arrow symbolizes my car spinning out of control?:lol: :lol: :lol:
No, Not Spinning, BARREL ROLLING!!!!
:lol: :lol: :lol:
the gob is offline
Old 07-02-2009, 12:45 PM   #17 (permalink)
MachFive's Avatar
I wouldn't think you'd have any clearance issues as long as you get the right offset on the wheel. But finding tires in a 225/XX/16 might be a headache depending on what spec you're looking for.
MachFive is offline
Old 07-03-2009, 08:50 AM   #18 (permalink)
Slightly different situation but on track I run 15x7.5 with an effective 30mm offset in the front and the tires poke out of the fenders just a touch. Enough that there would be serious problems with a soft suspension.
you could get away with 16x8 probably if you could find them but fender rolling and camber would likely be necessary.
Edit: Here is a picture of my setup from the front
Also they, clear my svt clampers
Old 07-05-2009, 12:32 PM   #19 (permalink)
what 15" wheels do you run?
JEEPers is offline
