Exedy
Sponsored by: The Tire Rack
Old 07-06-2008, 01:58 PM   #26
Pappy
Default Re: Most aggressive Offset with 215/45/17 and lowered?
It's all about how odd (or how much you want to spend to get the desired stance, haha) you want to be, haha.
This year I'm running full coilovers dropped 2.5" in front, 3" in rear. With -2 degrees camber in the rear and -1.5 in the front. I am running a 215/40 on an EAP with a 7mm spacer.
I damn near guarantee the fenders will need to be rolled....
Now that's rolling gangsta son.
2001 ZX3 JRSC 'Vader' - 199whp/166wtq. - MNFOCUS Boost Crew Stylez....
2002 ZTS 5-Spd .... Super Stock .... Yea, your jealous.... $2.14!
o2designs, is my little brother.
Pappy is offline   Reply With Quote
Old 07-06-2008, 04:37 PM   #27
o2_designs
Resident Wheel-Whore
Your a noob...hush up...
~~Boost Crew supports single mothers~~ _/ ResidentWheel-Whore\_
'Bone Stock'2002 TwilightBlue ZX3-Neglect has led to a nasty whine from under tha rusty hood. (CHROMED)
STS Prep'd 2001 Pitch Black 5spd Wagon-(666-STFU)
"...That way I don't have to clean my sheets..."-Pappy, 2008
o2 has already won so he is no longer eligible.-Ataru
Old 07-06-2008, 04:52 PM   #28
Pappy
You're just jealous. Poser....
Old 07-06-2008, 04:54 PM   #29
o2_designs
LOL...don't even start with offsets...you know you don't have nothing on me...
I do have a nice set of 7mm spacers sitting here that might look good on my Wagon...
Old 07-06-2008, 06:53 PM   #30
ladybug04
and full coiovers with -1.5* up front, and -2* in back?
you know that more in front is better for handling right? and being dropped that much you have actually lose camber up front when turning?
Some
Over worked
Honda
Originally Posted by TXFO
ladybug04 is offline   Reply With Quote
Old 07-08-2008, 09:05 AM   #31
rosko311
it also depends on the width of the rim that dictates some of the offset youd run. a 7.5 width rim with a 45 offset would run ALMOST the same as a stock 7 inch SVT rim with a 49 offset.
2003 Pitch Black SVT Focus #1586 of 3985---->
K&N Panel Filter, CFM 67mm TB, CFM ORP, Motorcraft Coppers, CFM Race Lower Trans Mount, Steeda STS, Spec Stg 1 w/ Steel FW, Focussport Tune, Saleen RC Suspension, 17" FB Rota Slips
rosko311 is offline   Reply With Quote
Old 07-10-2008, 09:29 AM   #32
hEaT
...On the strut side. On the fender side it would sick out more than a 17x7 wheel with a 45mm offset.
Tuned By: Bristol Dyno
hEaT is offline   Reply With Quote
Old 07-11-2008, 07:23 AM   #33
rosko311
hence the word ALMOST
Old 08-08-2008, 07:53 PM   #34
Jive Turkey
Jive Turkey is offline   Reply With Quote
Old 08-08-2008, 08:02 PM   #35
Jive Turkey
16's up front... 17's in the back
Old 08-08-2008, 10:37 PM   #36
ladybug04
pimptastic!
Some
Over worked
Honda
