NASA Spec Focus
Sponsored by: The Tire Rack
Old 03-31-2008, 02:12 AM   #1
Lumadar
Exclamation Most aggressive Offset with 215/45/17 and lowered?
I just installed the SALEEN lowering kit, and I am going to order my 17s on Tuesday along with my 215/45/17 tires from DISCOUNT TIRE.
I am looking to really fill out the wheel wells and I don't want the wheel overly receded back inside, but on the same note I don't want it to rub the fender or stick out either.
What offset (or range) should I go for? The wheels I was looking at are 42, but I am afraid that is not going to work.
Lumadar is offline   Reply With Quote
Old 03-31-2008, 04:01 AM   #2
Terry1
Default Re: Most aggressive Offset with 215/45/17 and lowered?
I'm using a 42 offset, but with 225/35/17 on 7 1/2" wheel.
Terry1 is offline   Reply With Quote
Old 03-31-2008, 04:09 AM   #3
Stolle
with 49mm offset EAPS on 215 45 17.
with Exel F1's 17x7 42mm offset with 215 45 17 neo gens.
2001 Zx3 with many parts. Thinking of selling/Parting out.
Stolle is offline   Reply With Quote
Old 03-31-2008, 08:24 AM   #4
Lumadar
Kick arse. Thanks guys!
Old 03-31-2008, 11:09 AM   #5
o2_designs
Resident Wheel-Whore
Most aggresive would be a 43-45.
I have some rubbing with my 215/45R17 with a 42 offset. But thats when people are in back seat or with a stereo in.
But to be safe, a 47-49 is what I'd recommend.
~~Boost Crew supports single mothers~~ _/ ResidentWheel-Whore\_
'Bone Stock'2002 TwilightBlue ZX3-Neglect has led to a nasty whine from under tha rusty hood. (CHROMED)
STS Prep'd 2001 Pitch Black 5spd Wagon-(666-STFU)
"...That way I don't have to clean my sheets..."-Pappy, 2008
o2 has already won so he is no longer eligible.-Ataru
Old 03-31-2008, 11:17 AM   #6
hEaT
49mm would be great. Doesn't look "sucked in" and no rubbing issues whatsoever.
Tuned By: Bristol Dyno
hEaT is offline   Reply With Quote
Old 03-31-2008, 12:30 PM   #7
Lumadar
Crap, well I have a fairly heavy arse stereo back there.
The wheels I was looking at are Oz Hydras, 17x7 with a 42MM offset, and I am going to be running the Kumho Ecsta MX tires...of which I can't find a true section width rating for the life of me. not even Kumho has it listed...
Think that will rub with the Saleen drop?
Old 03-31-2008, 12:40 PM   #8
o2_designs
In the rear, most likely yes...
When I did my MXs for autoX so I did'nt rub any, I went with a 215/40 R 17. Maybe an option? Don't know.
But the rear fenders will most likely rub, even if you roll the fenders, which mine are, and still rub once in a while...
Old 03-31-2008, 03:53 PM   #9
Stolle
i ran 215 40 17's with no rubbing issues but when i went to a 215 45 17 i rubbed. is say a 42mm with a 2" drop is alright on 215 40's. u gotta play with it some more.
Old 03-31-2008, 06:26 PM   #10
o2_designs
By play, you mean camber wise? LOL
Each manufacture has their own idea of a 40, or 45 series sidewall. So it depends on tire. But sounds like any 215/45R17 on a decent drop will rub on a 42mm offset. I never rubbed with a 47mm offset on 215/40R17.
Old 03-31-2008, 08:04 PM   #11
Stolle
nope me ethier.
and yea i mean camber. silly vikings fans...
Old 03-31-2008, 08:54 PM   #12
bunksvt
i never rubbed with 215 45 17's and a 2" drop on Stock EAP wheels.
by the looks of my clearance which was NONE lol....the farthest I would come out would be a 45mm offset
I like it rough
bunksvt is offline   Reply With Quote
Old 03-31-2008, 09:30 PM   #13
Lumadar
Which kit exactly did you have? I have a 2006 ZX3 with the SALEEN kit...any idea how they compare?
I would ideally like to run the 45 series, but I don't want to have a serious rub either...
Also, excuse my ignorance, but the lower the offset the more it comes out, right? so a 45 for instance would be less aggressive than a 42?
Old 03-31-2008, 11:14 PM   #14
hEaT
Correct on the offset. The higher the number, the closer it is to the hub.
The EAP wheels are +49mm.
Old 04-01-2008, 11:20 AM   #15
o2_designs
Originally Posted by Stolle
nope me ethier.
No Viking Fans here!!
Old 04-01-2008, 12:18 PM   #16
bunksvt
yah you got it...i had tein s techs just a 2" drop...similar to sportlines in stance and spring rates...im switching to intrax cause I want something stiffer....but u should be fine with the 49mm offset and ALMOST any drop
I like it rough
Old 04-01-2008, 07:59 PM   #17
Stolle
well. ummmm. idc ur from the evil side of the river. haha
Old 04-01-2008, 08:06 PM   #18
ladybug04
well i have the H&R cup kit w/ 40mm offset kazeras, and some kelly fierces, and rub like crazy up front, but no rubbin in the back?
Some
Over worked
Honda
Originally Posted by TXFO
ladybug04 is offline   Reply With Quote
Old 04-06-2008, 12:55 AM   #19
Super Cab L
Tire Rack has the specs your looking for: http://www.tirerack.com/tires/Spec.j...irePageLocQty=
Roy
TCE Brakes,18in. Centerlines,Dyna-Batt battery,BILSTEIN PSS9 Coilovers,Tubular front control arm,K-Mac's,Powergrid end links,Camber Blade,Progress rear swaybar,Random Tech Cat,Borla cat back,Focus Sport X-Cal 2,harness bar,Steeda Short shifter, quaife
Super Cab L is offline   Reply With Quote
Old 04-07-2008, 12:00 PM   #20
o2_designs
My wagon rubs up front, my hatch rubs out back...
My wagon has KW green springs, and SVT 5 spokes with 215/45R17 tires. Rubs up front sometimes under hard corners. Depends on how I play with teh throttle...lol...
Old 04-07-2008, 12:34 PM   #21
hEaT
FWIW, I rub up front under full lock and big dips when I run my snow tires. 205/55/16 on the stock 16x6 wheels. I believe they are 52.5mm offset? I'd imagine the SVT guys would have a bit less trouble since their turning radius is a bit larger.
Old 04-08-2008, 09:25 PM   #22
eurozx3
I had 215/45/17's on my EAP wheels with an H&R Cup Kit and it rubbed on the front when I hit dips in the road.
08 Scion XB. Tanabe NF210 springs,MB Motoring Weapon wheels with 235/45/17 Falken 912's,Borla exhaust,tinted windows and clear bra.
eurozx3 is offline   Reply With Quote
Old 07-06-2008, 03:42 AM   #23
Nickgt40
I also have a Cup Kit, but with 45mm offset wheels, and it rubs like crazy in the front with 215/45/17s
Originally Posted by kiwizx3
Yeah what he said!
Nickgt40 is online now   Reply With Quote
Old 07-06-2008, 12:01 PM   #24
jimy_f_84
Im cofused, the more the offset the more towards the outside or inside the wheel/tire will go?
Example: i have the SVT wheels with 49mm offset, a caliper wouldnt clear the spokes so i need more offset or less offset?
Thanks in advance
05 Sedan Turbocharged Focus
JF
jimy_f_84 is offline   Reply With Quote
Old 07-06-2008, 01:46 PM   #25
ladybug04
offset is distance of the hub face from the center line of the wheel, lower will stick the wheel out more, higher number is more sucked in.
oh and i took care of rubbing up front by throwing some 215/40/17 dunlop direzza dz101 z1 star specs on.
Some
Over worked
Honda
