if i paint the new rotors with some rustoleum or something along those lines when the rotor is brand new, will it for sure prevent the untouched protion black and rust free?
thanks
-Ken
Sponsored by: The Tire Rack |
#1 |
thanks -Ken
Blackedout '02 SVTa.k.a. "The Haunted House" Eibach Sprotline Springs,Diablosport Predator, Custom Intake, ORP, Torson T2, Steeda Tri-ax |
#2 |
Many companies powdercoat rotors for the same reason. It looks pretty badass, especially on slotted rotors. Your typical rustoleum will probably flake off after short time because the rotor gets very hot. You'll need some hi-temp paint. Post up some pics when you get finished. I've seen 'jetters use silver, but never black. Good luck
Mountain Tested----'03 zetec DuraMonster---'03 duratec ZX3 vs MNTN - 9/0 & ZX3 vs TRACK - 4/1 JCM Racing #88 Bouncing Back---Bigger, Faster, Stronger Executive Head Chief Administrative Supporting Subordinate Supervisor - Vacuum Vulture Racing |
#3 |
i painted my mustang rotors with high temp gray primer before i put them on last summer and they still look awesome to this day. no rust. i made multiple coats across the front and rear of the rotors to cover all surface area and also sprayed into the fins.
as soon as you drive the car it burns off the pad contact area within a few miles, just be careful during the period because the car does not stop well until it all burns off.
1998 Mustang GT, Vortech T-Trim(16#s intercooled), Forged 302 stroker, Stage 2 Ported Polished Heads, Comp XE274 Cams, Ported/Polished Bullitt Intake Manifold, TKO Trans, 03 Cobra IRS swap. http://rides.webshots.com/album/559219923mdvdiw 2002 SVT Focus #3473 of 4788 born on 7-24-02 K&N Filter w/silencer removed, EAP HID headlights, SCT Tuned, CFM Adj STS, Black EAPs |
#4 |
Are you nuts, you painted the entire rotor and then drove it to burn off the paint..WOW that's classic!!
Prettycar..don't do what he just said..paint only the area that does not come into contact with the pads.
Johnny Tapia is my hero! |
#5 |
i know not to paint on the contact area, just wanted to see if the rustoleum would work. but ill get some high temp paint.
thanks for the help -Ken
#6 |
painted surfaces don't shed heat very well, such as caliper paints. They look nice, but help retain heat like header wrap. IMO if it's a show car go for it, if it's not, i wouldn't do it.
5 red LED's, missing floormats: 2000 zx3 totaled 02' Silver SVT, new motor |
#7 |
well having an all black car, a rust ring is very much an eye soar and i am not too worried about and heat retention cause i dont run the car hard. just turned 80k, shes gettin old.
i masked them off and painted them last tuesday, they cam out great. i will prob. ull them off in a couple weeks and reapply on the areas i didnt paint. i could have waited longer to untape and install, the paint peeled alittle when i pulled off the tape. but its all good. i used some kinda header or block paint, good up o like 1200 degrees or something. so it should be good. -Ken
#8 |
i used rustolem on my drums one side looks perfect the other one chipped badly kinda weird but switching to a full svt setup so it sould be nice
#9 |
Does anyone have any anti-rust solutions for the underbody?
I want to try to keep my car's bottom parts from rusting too badly in the Massachusetts winters.
'04 PWSC SVT with LSD, HFC, and STS |
#10 | |
These are "Functional" Parts, NOT "Pretty Parts". You don't put vaseline on your shoe soles, and you don't paint or lubricate your rotors. The Hat.... Maybe. You usually can't really see it anyway. If you're talking about painting the flat side of your rotors except for the contact area, I'd have to say, "That's a New One.....??!!!??? ", but if all you do is cruise, and there is a gap between the paint and the contact area, I GUESS it would work,.... If that's cool to you or something...??? ![]()
On Capitalization:
#11 | |
My 02 ZX3 has weathered multiple indiana winters with no rust at all underneath the car. I am thinking about some rubberized under coating, I figure 3 to 4 cans will do the inner fenders and under side of the car. At $20-$30 I see it being a good investment.
'02 Liquid ZX3 Power Premium MTX 4-1 header, custom 2 1/2" flex and catback, CAI, custom Eibach Springs, KYB AGX's, painted 6 spokers, 225/50/ZR16's, B&M sts, Hurst knob, SVT cluster, Scangauge II, vac/boost & AFR gauges, 5% tint all arround, projectors with halo's, tail light covers, (2)12" Audiopipes w/3k watt amp, Jensen VM9512 headunit. |
#12 |
Painting the brake discs (not the portion that comes in contact with the actual pad) can help make things look a little "neater" or "cleaner". Instead of paint, though, why not try something a little different, and brush on some of that (gimmicky??? yes? no???) "rust converter paint"? I only say this because it's another, perhaps weird, option you can try out for the discs. Otherwise, for my discs, I painted the part that is near the wheel (that no one can really see, wow) with simple black charcoal grill paint. Lasted one Pennsylvania winter, then pretty much flaked off and is back to rust again. So be it.
I'm not sure you'll need the rubberized undercoating, but it'd be neat to see what it all looks like. As for me, I just rolled my fofo on ramps last year, took a wire brush to spots showing rust (that I could reach), then scrub, scrub, scrub-a-dee-dubbed away. Shot the bare spots over with rusty metal primer, then shot another layer of flat black paint, good to go. Lastly, I remember reading waaay back in the day that that rubberized coating can actually (probably an Old Wives Tale, mind you) "trap moisture" and "cause rust". Credible? Reliable reporting? Nope; just something I heard--take it with a grain of salt. --Scott
MOVE: PWSC with c-f-m tb, esslinger gears, McNews Tune, J&S Safeguard, Optima red, c-f-m wires, cobra pcv, VF lower mount, SVT header, TruBendz 2.5" flex/exhaust Groove: SVT shocks/struts, Vogtland springs, Eibach antirolls, Ecsta asx Stop: Hawks Look: Yellow painted fogs w/Yellow Nokyas & I.F. Mod, Euro upper/lower grille, blk headlight paint, sedan taillight mod, Speedhuts, Mach lip from Tousley. |
| Thread Tools | |
| Display Modes | |
