Central Florida Motorsports
Results 1 to 14 of 14
    Newbie
    Jun 2008
    2
    Default Vibration on highway
    Im looking for some help here, I am getting a vibration in my 2001 focus ZX3 at speeds above 65. Just so everyone knows, I just put tires on it last Saturday and had it aligned. I then took it back and they rebalanced the tires. It help but not totally. I then took it back again and they told me the tires were perfect. The problem did start before I purchased the new tires so it could be possible. I have also replaced the ball joints, and the links between the torsion bar and the strut. The tie rods have no play at all in them. I was told that it could be the wheel bearings. With these bearings having balls instead of rods I think it could be possible even with no noise and shaking the hubs with the tires off for them to be bad. Any input is greatly appreciated,
    Thanks
    Will
  2. #2
    Aug 2000
    Cedar Hill, TX, USA
    125
    Default Re: Vibration on highway
    Lift up the car, see if you have any movement in the wheel (leave the wheel on). If you do, replace the hub, easier than doing the bearings.
    If the wheels are balanced correctly, that's about it for the vibration at highway speeds. Also, remember it could be the rear wheels as well. You should be able to tell if it's coming from a particular corner of the car.
  3. #3
    Newbie
    Jun 2008
    2
    Thanks for the help. I can only feel the vibration in the steering wheel, so I hope its only coming from the front. Also when you do the hubs dont you still have to take the spindle off the have the bearings pressed out, or does the hub and bearing slide out of the front of the spindle. Thanks for the help,
    Will
  4. #4
    Super Moderators GapBoyPCS's Avatar
    Oct 2001
    11,253
    There are several posts in our Tires/Brakes section. I'll move this post there for additional input.
    Richard
    2002 ZTS | Sangria Red |
  5. #5
    Nov 2007
    Canada eh!
    100
    I have the same problem on my car as well! The steering wheel shakes a lot at hwy speeds. Let me know if you solve your problem and what was the cause of it.
    Black 2005 Ford Focus Zx4 ST
    http://www.cardomain.com/ride/3067845
  6. #6
    Feb 2005
    Kunia, HI
    1,347
    I have this too, but it's not just at highway speed, it starts at about 25 mph but will go away when I turn my steering wheel to the right.
    Recon = bad.
    Ford Focus Hawaii
    2003 Black ZX5
    Mods: HID, LiveWires, Dirt
  7. #7
    LET'S GO RIDE BIKES robb's Avatar
    May 2001
    Los Osos
    2,759
    What condition are your tires in? I had the same problem on my Focus and it was caused by a tire being worn out of round.
    The OG 'jetter formerly known as 'robbyracer'
    2012 Focus SE Sport
  8. #8
    Nov 2007
    Canada eh!
    100
    My tires are brand new
  9. #9
    Jun 2008
    37
    maybe it's your cell phone
    Stay Focused
    TRP|Sparco
  10. #10
    Apr 2004
    Edison, NJ
    462
    most likely that the tires are not perfectly round. Tire shops will decline responsibility because there is no evidence that the tire is faulty.
    Swap front ones to the back - see if that helps. Most likely the vibration will go away. Mine did. When I rotated them back to the front 10k later the problem did not reappear.
  11. #11
    Oct 2001
    11,253
    Have you folks tried a roadforce balance?
    Richard
  12. #12
    Feb 2005
    Kunia, HI
    1,347
    Quote Originally Posted by robbyracer
    Got them feb 29
    Recon = bad.
    Ford Focus Hawaii
    2003 Black ZX5
  13. #13
    Aug 2005
    OR
    477
    I had this exact same problem. Road force didn't help one bit. Finally, I had to get Tirerack to replace two of my tires, although it helped slightly, the car rode better on stock steelies + tires.
    and to rub salt in the wounds, Les Schwab scraped up the lip of my wheels. They still use center post machine.
  14. #14
    Newbie
    Jun 2008
    Metro NYC
    1
    FYI-my fairly new (18K miles) Kuhmo Ecsta ASTs seem to vibrate a bit at hwy speed. Looked into it, and discovered that there's no balancing out damage to wheels caused by NYC potholes. The Ford stock wheels on my 06 ST are so soft, they can bend from spanking city streets!! Final fix-buy the package of wheels and tires when you log onto TireRack.com!
