Sponsored by: The Tire Rack
Old 06-29-2008, 07:24 PM   #1
rallyrabbit
Default Brake Pedal engages really high on the pedal after bleeding
Scenario. 2005 Focus ZX3 SE. All new rotors and drums within 2 months. Using Carbotech Bobcat pads on the front, and stock stuff on the rear.
Noticed about 4 weeks ago that i was getting some major brake noise on the front drivers side. Thought it was the pads never being at true operaitng temp, so I ignored until I noticed I had brake dust on the front drivers side and none on the passenger side. Thought it was strange.
Jacked the car up, and I could spin the tire (with real effort on my part) if the brake pedal was depressed. Thought it was strange, bled the brakes, that problem seemed to go away.
Now, my pedal engages near the top. Like, very close to the top. Never had a pedal engage that far up. And this only happened after I bled the front driver's side. I seem to have plenty of stopping power, but it just engages funny. It feels like the booster is working since if you depress the pedal and start the car the pedal will go down slightly.
Any opinions on things to try?
rallyrabbit is offline   Reply With Quote
Old 06-29-2008, 07:51 PM   #2
orionlion82
WARNING: This post may be hazardous to your health.
Default Re: Brake Pedal engages really high on the pedal after bleeding
air in the lines?
orionlion82 is offline   Reply With Quote
Old 06-29-2008, 08:23 PM   #3
MichaelXi
[FJ] Addict
Any change in the dusting after bleeding?
Does the car Pull under braking if you release the wheel?
MichaelXi is offline   Reply With Quote
Old 06-30-2008, 07:08 AM   #4
rallyrabbit
No, that's the weird thing. Seems to be even braking, but then, it seemed to be even braking when there was air in the lines before too.
I guess I will pull it all apart and bleed the whole system today or tomorrow.
Old 06-30-2008, 09:52 AM   #5
brads03zx3
Sounds like there is no problem. You fixed the issue. An excellent braking system engages with minimal displacement. This means you probably had a lot of air in the system before hand, so that air was compressing before the caliper was effective causing a low pedal.
Mountain Tested----'03 zetec
DuraMonster---'03 duratec
Old 06-30-2008, 04:57 PM   #6
Reza
Formerly focus_wrc
x2
H&R/// , Team Dynamics , FocusSport , TCE Brakes, Bridgestone.
Reza is offline   Reply With Quote
Old 07-02-2008, 01:26 AM   #7
Johnny_P
x3
If you really think there's a problem, you can take your wheels off and re-grease your slide pins... That should only take like an hour, and most of that time will be jacking the car and taking wheels off
Do you..... Focus?
Originally Posted by Chalz
it seriously felt like someone pinned some Ritz crackers to the side of a potato and stuck a Toyota logo to it
Johnny_P is offline   Reply With Quote
Old 07-12-2008, 08:41 AM   #8
rallyrabbit
Going to pull it all apart anyway today.
Noticed that the right front brake rotor is running way hotter than the passenger side. So either, I have a bad master cylinder distributing unequal pressure, something is in the line, or something is binding under pressure (because there is no binding when the brake pedal is off)
Old 07-21-2008, 01:06 AM   #9
TooStock
Generally your shoe (meaning, rear drum brakes) adjustment effects your brake pedal height and travel. Set too tight you'll have a short pedal, set too loose and you'll have excessive travel.
TooStock is offline   Reply With Quote
Old 07-21-2008, 11:20 AM   #10
hEaT
The rears are auto-adjusting correct?
Tuned By: Bristol Dyno
Old 07-21-2008, 08:30 PM   #11
brads03zx3
Yes, until they are changed. Once the shoes are replaced, the adjuster must be backed off.
Old 07-22-2008, 08:46 PM   #12
rallyrabbit
Ok, so my pedal is still really frickin' high. It doesn't feel right still.
Here's what I've done between the last message and now:
-Pulled apart front brakes, inspected, greased pins and put back together
-Replaced front rubber brake lines
-ensured that shoes were adjusted (they aren't dragging)
-Bled the brake system 3 times
-No ABS, so that isn't a concern
So. The problem still occurs. I have about 1" of pedal travel, other focuses I have access to have about 3" of travel. The pedal is always firm, so there is never a loss of pressure (or it doesn't seem to be).
Observations:
-Front driver's side rotor is always running way hotter than passenger side. Water sizzles off this side. The other side is hot, but water quickly evaporates off rather than sizzle off.
-Since I don't feel a drop in pressure, I haven't considered the master cylinder to be the problem. Is that wrong?
-Could this be a vaccum or booster problem? Meaning, could I be running without the booster working somehow? If so, how can I test or tell if that is the case?
Any other recommendations?
Old 07-23-2008, 04:46 PM   #13
Stolle
dont put water on ur hot rotors....good way to warp and crack them.
2001 Zx3 with many parts. Thinking of selling/Parting out.
Stolle is offline   Reply With Quote
Old 07-24-2008, 01:57 AM   #14
brads03zx3
Here, let me say this again:
As far as an early engaging pedal, you are complaining about a good thing. It's like saying "Recently, I haven't found any of my clothes or CD's in my little brother's room. He's even doing the chores that mom asks him to do. What's wrong? We took him to the doctor, but that stupid guy says he's healthy. What should I do?"
Both of my foci have firm pedals. This is because I don't wait 5 years to replace the brake fluid, the pads have plenty of material, and there is no air in the lines. In a perfect world, the pedal would not move at all. The brakes' effectiveness would only be a function of pedal pressure, and have nothing to do with pedal displacement. Unfortunately, materials flex, so the pedal usually moves. Your brakes are fine. Be happy
Now, if one side is hotter than the other (your experiment isn't very scientific, and can get expensive) this could be for several reasons. Does the car pull to one side under braking? If not, you again have nothing to worry about. If it does, you may have some debris in the line clogging one sid, or you may have a bad caliper, etc.
Old 07-24-2008, 08:08 AM   #15
rallyrabbit
Yes, I know. We are talking a couple of drops from a dropper not a full blast of water from a hose.
Old 07-24-2008, 08:10 AM   #16
rallyrabbit
Ok, will some of your humor me. We you check and measure your brake pedal travel and at least tell me yours for comparison?
Nope, not scientific at all! Car does not pull to either side under braking. Drivers side doe s have more dust collected on the wheel the the passenger side.
Old 07-24-2008, 10:39 AM   #17
OmniFocus
The less travel the better.... that's precisely why I have forged four-piston calipers and stainless steel brake lines. I *want* my pedal to feel like I'm stepping on a rock.
Old 07-24-2008, 02:19 PM   #18
Omega Anomaly
I would have to agree with everyone. A good firm pedal with minimal travel is what you want. If you had a good amount of travel afteer you did the brakes, then there would be cause for concern. As far as the drivers side being hotter than the other, it is of no concern if the braking is not pulling to one side or the other, atleast you are getting equal brake pressure to both calipers and both calipers are working. There are only a couple things I can think of on why the one side maybe hotter than the other.
1. Possibly either the rotor thickness or brake pad thickness is a little more on the drivers side, which would go away with time.
2. Either the pins or the piston is not moving as freely as the pass side, slower recovery time from when the brake pedal is released.
Maybe you could have someone else push on the brake and let off and try to spin the wheel upon realease to see if there is some drag from a slow recovery.
Later
-Bryan
"How can we set up a democratic government in a country, when we are a republic. It is like saying 'This is how you do it, but don't look at my example because it is wrong' ."
Omega Anomaly is offline   Reply With Quote
Old 07-24-2008, 08:12 PM   #19
Johnny_P
sometimes those slide pins get warped from overtorquing or overheating without grease.... They're like $5 a set from autozone though.... hey its a shot
Do you..... Focus?
