Ok this is hopefully going to be my last problem with alignment. My pass strut tower is bent, now i have 2.3 degrees camber adn 1.5 on drivers side. Current toe is set out at .02 each side.
I was also told for best tire wear 0 toe is optimal, but for our cars being fwd when getting up to speed the tires will actually toe in, so being toed out will result in 0 toe setting when rolling due to this factor.
I just need someone to confirm this because I am having my alignment done ONE more time and I want to know if mismatched camber is going to be an issue and if just setting the toe correctly will be good, or I should set it to zero all around. The car is a daily and is NOT auto-x'd or anything of teh sort, jus a to and from work and night out car.
) and a frame shop can't straighten it.
Linear Mode
