Sponsored by: The Tire Rack
Old 07-05-2008, 04:35 PM   #1
EggYolk_Zetec_ZX3
Default Question about Wheel Offset...
If someone could verify this with me, or if I have it backwards... I am trying to determine how wheel offsets differ...
Just for the ease of discussion...
A wheel with an offset of 45mm is going to stick out further than one with a 50mm offset. Or do I have this reversed?
I ordered a set of ASA AR2s for my GTI, but they won't be in until the end of July... I've been getting antsy, and now have completely changed my mind, and I want to go for Borbet Type XL, the only difference is the offset, and I'd eventually like to lower the car some, and I don't want rubbing issues.
Thanks in advance!
Current Car - MkV GTI 2.0T Reflex Silver w/DSG
Previous Car - 2002 Sonic Blue SVT #2769 of 4788 Built June 13, 2002
Wife's Car - 2007 Silver Birch Metallic Ford Fusion SE
EggYolk_Zetec_ZX3 is offline   Reply With Quote
Old 07-05-2008, 06:41 PM   #2
eurozx3
Default Re: Question about Wheel Offset...
The 45mm offset will stick out further than the 50mm.
08 Scion XB. Tanabe NF210 springs,MB Motoring Weapon wheels with 235/45/17 Falken 912's,Borla exhaust,tinted windows and clear bra.
eurozx3 is offline   Reply With Quote
Old 07-05-2008, 09:23 PM   #3
ZX3TUNING
offset is the distance in mm forward(+) or back(-) for the centerline of the wheel width.
the higher the number the more wheel on the INSIDE
the lower the number the more wheel on the outside.
0 offset or ET means the wheel mounts dead center in the width.
8" wide wheel you'll have 4" on either side of the hub surface.
one thing lots of people miss/neglect or don't know is the offset and center line are from between the inside of the lips where the tire mounts not from the outside faces of the lips.
this is
Power in Style.... ZX3Tuning
Part of Conglomerate Motorwerks!
Mitch A.
ZX3TUNING is offline   Reply With Quote
Old 07-06-2008, 11:07 AM   #4
jimy_f_84
so if i have a 49mm offset wheel that clears the caliper by a credit car, and i want another wheel with 45mm offset then i should be fine right?
05 Sedan Turbocharged Focus
JF
jimy_f_84 is offline   Reply With Quote
Old 07-06-2008, 12:09 PM   #5
o2_designs
Resident Wheel-Whore
Yes, if its the same style wheel. Different wheels have different spoke characteristics(sp?)
But theoritically, yes, they should fit better, since the wheel is pushed away from the car.
~~Boost Crew supports single mothers~~ _/ ResidentWheel-Whore\_
'Bone Stock'2002 TwilightBlue ZX3-Neglect has led to a nasty whine from under tha rusty hood. (CHROMED)
STS Prep'd 2001 Pitch Black 5spd Wagon-(666-STFU)
"Your mom has an SVT bumper..."-Pappy, 2008
--No longer allowed access to FJ 'For Sale' Forums. Has a uncontrollable urge to buy stuff I don't need--
o2_designs is online now   Reply With Quote
Old 07-06-2008, 03:52 PM   #6
jimy_f_84
thanks alot found some sweet 16X7 forged 12 lbs each for the track but they are $316 a pop >
JF
Old 07-06-2008, 03:54 PM   #7
ZX3TUNING
spoke design and caliper padding on each wheel is different.
worst comes to worse, you can always add a small spacer to get the caliper clearance you need.
Mitch A.
Old 07-06-2008, 05:05 PM   #8
jimy_f_84
True, and 5-10mm spacers shouldnt be that hard on the studs or the hub bearing right?
JF
Old 07-06-2008, 07:18 PM   #9
EggYolk_Zetec_ZX3
Thanks for answering my question! I found a website with a formula that shows what the difference would be, and for some reason yesterday (lack of caffeine I guess) it wasn't clicking in my head.
