Ford Racing Performance Parts
Sponsored by: The Tire Rack
Old 08-07-2008, 09:08 AM   #1
MachFive
Default Smaller SVT Rotors?
Has anyone seen or bought any rotors for an SVT that are smaller than stock? I have 16's that don't fit over the stock brakes + calipers, so i'm looking for some rotors that are an inch or so smaller than the OEM ones. Any help is much appreciated!
MachFive is offline   Reply With Quote
Old 08-07-2008, 09:16 AM   #2
Chaney
Default Re: Smaller SVT Rotors?
If you do smaller rotors, then you have to relocate the Caliper also. Basically do a reverse SVT to ZX3 brake swap.
I'd think the wheels would not be worth the loss in braking power.
Chaney is offline   Reply With Quote
Old 08-07-2008, 10:14 AM   #3
MachFive
Oh they're worth it. For as much time and money as i spent on them, pretty much anything is worth it at this point.
Old 08-07-2008, 10:18 AM   #4
sleeperlove
Focus ST front brakes are slightly smaller than the SVT hardware.
sleeperlove is online now   Reply With Quote
Old 08-07-2008, 10:23 AM   #5
focusownerskid
Administrator
Spacers or a Ford Racing Rally brake kit.
Or, i'll straight swap ya for fresh set of ZX3 front brakes
'02.5 SVTF - For Sale;
http://forums.focaljet.com/vehicles-...svt-focus.html
'01 Turbo ZX3 - For Sale;
http://forums.focaljet.com/vehicles-...ml#post6770262
type dRew & friends Motorsports.
focusownerskid is online now   Reply With Quote
Old 08-07-2008, 10:28 AM   #6
OmniFocus
Exactly... Any 05-07 rotor & caliper combo will be exactly what you need. Same swept area with a smaller diameter.
OmniFocus is online now   Reply With Quote
Old 08-07-2008, 10:38 AM   #7
hEaT
And those should bolt right up to the SVT knuckle too AFAIK.
Tuned By: Bristol Dyno
hEaT is offline   Reply With Quote
Old 08-07-2008, 12:14 PM   #8
MachFive
Oh sweet! The ST's sound like exactly what the doctor ordered! So who's got any they need to get rid of?!
And Drew, straight up doesn't sound like such a great deal.
Old 08-07-2008, 12:26 PM   #9
MachFive
Oh, and are the STs rears the same way? Bolt on, but a bit smaller?
Old 08-07-2008, 12:42 PM   #10
mysvtftoy
SVT rear brake assemblies are a lot smaller than the SVT front brakes, aren't they? Seems like any 16-inch wheel that would clear those ST front calipers would clear the SVT rears. No?
money pit | gas hog | schedule | YouTube vids
mysvtftoy is offline   Reply With Quote
Old 08-07-2008, 12:54 PM   #11
MachFive
I'll have to test fit the wheels again, but they didn't clear the first time i tried them. I could have been in a haze brought on by disbelief at the fronts not fitting, however.
Old 08-07-2008, 01:50 PM   #12
OmniFocus
Heck, any 15" wheel will clear the SVT rear brakes.
I'm curious to see what 16" wheel you've found that doesn't fit the front!
Old 08-07-2008, 02:21 PM   #13
Chaney
I would try to find an ST first and see if your wheels fit before ordering the ST package and putting it on your car.
Seems there should be one in the area.
Also very interested to see what wheels you are wanting to run to get them to fit this badly.
Old 08-07-2008, 04:35 PM   #14
MachFive
Well, i'll have pics up as soon as humanly possible, believe me!
I'll give ya a hint: they're from Italy, and they're stamped July 1992. And they're originally from a European Ford product. I think.
Old 08-08-2008, 01:32 AM   #15
brads03zx3
Leo Capaldi has the only ST with a 2.0 duratec. I think soon you may have the first SVT with an inferior brake setup
Mountain Tested----'03 zetec
DuraMonster---'03 duratec
Old 08-08-2008, 08:17 AM   #16
MachFive
I was wrong...turns out they do fit on the rear. And Corey (CTCZX3) has some 08 brakes that hopefully i'll be able to bolt up here real soon and finally put the fronts on.
Thanks for all the input guys. I really appreciate it!
Old 08-08-2008, 09:30 AM   #17
brads03zx3
Can you post a picture of the interference you are getting? What is the offset of the wheel? We haven't seen many issues with 16" wheels over the SVT calipers.
