Sponsored by: The Tire Rack |
#1 |
Has anyone seen or bought any rotors for an SVT that are smaller than stock? I have 16's that don't fit over the stock brakes + calipers, so i'm looking for some rotors that are an inch or so smaller than the OEM ones. Any help is much appreciated!
#2 |
If you do smaller rotors, then you have to relocate the Caliper also. Basically do a reverse SVT to ZX3 brake swap.
I'd think the wheels would not be worth the loss in braking power. |
#3 | |
Oh they're worth it. For as much time and money as i spent on them, pretty much anything is worth it at this point. ![]() |
#4 |
Focus ST front brakes are slightly smaller than the SVT hardware.
I'm in ur posts changin ur werdz. |
#5 |
Administrator
Spacers or a Ford Racing Rally brake kit.
Or, i'll straight swap ya for fresh set of ZX3 front brakes ![]() - Drew
'02.5 SVTF - For Sale; http://forums.focaljet.com/vehicles-...svt-focus.html '01 Turbo ZX3 - For Sale; http://forums.focaljet.com/vehicles-...ml#post6770262 type dRew & friends Motorsports. |
#6 | |
Exactly... Any 05-07 rotor & caliper combo will be exactly what you need. Same swept area with a smaller diameter.
**Check out the shiny new PirateNinjasWithLasers.com for the latest updates in 24 Hours of LeMons goodness.** Vacuum Vulture Racing: We put the "rad" in scrub radius, and the "ack" in ackerman. |
#7 |
And those should bolt right up to the SVT knuckle too AFAIK.
2001 Twilight Blue ZX3 - Volant Intake, FC 65mm TB, SVT Header, RT High Flow Cat, SVTF Borla Exhaust, Koni's 1985 Nimbus Grey Merkur XR4Ti - Work In Progress Tuned By: Bristol Dyno |
#8 |
Oh sweet! The ST's sound like exactly what the doctor ordered! So who's got any they need to get rid of?!
![]() And Drew, straight up doesn't sound like such a great deal. ![]() |
#9 |
Oh, and are the STs rears the same way? Bolt on, but a bit smaller?
#10 | |
SVT rear brake assemblies are a lot smaller than the SVT front brakes, aren't they? Seems like any 16-inch wheel that would clear those ST front calipers would clear the SVT rears. No? |
#11 | |
I'll have to test fit the wheels again, but they didn't clear the first time i tried them. I could have been in a haze brought on by disbelief at the fronts not fitting, however. ![]() |
#12 |
Heck, any 15" wheel will clear the SVT rear brakes.
I'm curious to see what 16" wheel you've found that doesn't fit the front! ![]()
#13 | |
I would try to find an ST first and see if your wheels fit before ordering the ST package and putting it on your car. Seems there should be one in the area. Also very interested to see what wheels you are wanting to run to get them to fit this badly. |
#14 |
Well, i'll have pics up as soon as humanly possible, believe me!
I'll give ya a hint: they're from Italy, and they're stamped July 1992. And they're originally from a European Ford product. I think. ![]() |
#15 |
Leo Capaldi has the only ST with a 2.0 duratec. I think soon you may have the first SVT with an inferior brake setup
Mountain Tested----'03 zetec DuraMonster---'03 duratec ZX3 vs MNTN - 9/0 & ZX3 vs TRACK - 4/1 JCM Racing #88 Bouncing Back---Bigger, Faster, Stronger Vacuum Vulture Racing - We put the ARG in 'CHARGED |
#16 | |
I was wrong...turns out they do fit on the rear. Thanks for all the input guys. I really appreciate it! |
#17 |
Can you post a picture of the interference you are getting? What is the offset of the wheel? We haven't seen many issues with 16" wheels over the SVT calipers.
| Thread Tools | |
| Display Modes | |
