FJ Gear Store
Page 1 of 7 1234 ... LastLast
Results 1 to 15 of 101
    Almost choked on a Girl Scout ...cookie bigdaddyG8's Avatar
    Mar 2002
    Fresno, CA
    16,227
    Default 18" x 9.5" Wheel... what width tire?
    Okay... obviously... this is not for a Focus!
    My G8 wants meatier tires under it, but I want to keep the 18" dia size.
    Stock is 18"x8" and I think going to 9.5" width will fill the wheel wells very nicely and allow for some meatier tire underneath.
    Any resident tire experts (OmniscientFocus) want to chime in with opinion?
    Thanks!
    *and before you say "Go ask on the G8 boards"... well, I'm doing that too, but I respect the opinion of many of my FJ peeps, and there is tons of knowledge on here.
    Quote Originally Posted by Houdini View Post
    Mike, how are you going to prevent water entering the intake?
    Quote Originally Posted by svtf02red View Post
    Tiny Moses in the hood scoop.
  2. #2
    Currently listening to:
    The Thong Song
    Focusfre4k's Avatar
    Jul 2006
    3,793
    Default Re: 18" x 9.5" Wheel... what width tire?
    255/265 or so? thats what I would guess... what sidewall you looking at?
    2006-2009 Copper 2005 ZX5
    2009-2010 Red 2008 SE Coupe
    2010-now Velocity Red 2010 Mazdaspeed3
    Quote Originally Posted by BlkThunder View Post
    Oooooooh pm me the full pic of your wifes snatch!!! I just got me a fresh bottle of Jergins!!!
  3. #3
    Mar 2002
    Fresno, CA
    16,227
    Stock tire size is 245/45/18
    I want to retain the same profile
  4. #4
    Senior TEAM Member BOWERSdaAZIAN's Avatar
    Jun 2004
    Drought ridden CA
    2,857
    Is the stock setup staggered? TireRack lists a 245/45/18 so i am assuming not.
    I think a 275/40 is perfect. Not only is it meaty, but also the exact diameter of stock (26.7 in).
    You could run the stock size in front and that 275/40 in back. I think that would be your best bet.
    USAF Electronic Warfare Motto(s):
    "Jam Harder, Penetrate Deeper, Dispense Longer" & "In God we Trust... All Others we Monitor, Jam or Deceive"
    Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere
  5. #5
    Official [FJ] Distinguished Advisor Z63R's Avatar
    May 2004
    TEAM AllCal
    19,806
    Meaning, keep the same sidewall height and overall tire diameter.
    Bowerz
    That sounds delicious...
    "Wine tasting isn't bad, but given the choice, I'd rather drink left-over beer and replace brake pads." - OmniFocus
    2.3 Duratec ZX3 + some bits
  6. #6
    I change diapers now focusownerskid's Avatar
    Aug 2000
    Lincoln Park, MI
    13,945
    Come on now...if people can roll 10's on a Focus, you can do 11's on the G8.
    ///type dRew
    '99 Camaro / '02 Sunfire / '02 Jetta
  7. #7
    [FJ] Addict brads03zx3's Avatar
    Sep 2004
    Traffic
    11,368
    We were talking about that heading home from the grocery store last night.
    "I'd like a bit wider wheel."
    "Yeah, I agree. 18x12 would probably work well"
    Hale, how agressive of a tire are you looking to get? You want 20-25k miles or can you get away with half that? With an additional 1.5" you can increase your tread width by the same amount, or 30-40mm. You had mentioned stagger, are you looking to run a square tire setup? I wouldn't think you'd have any issues with a 255/275 setup on 8.5/9.5" wheels. If you wanted a square setup, I'd have to bust out a ruler to see how easy a 275 on a 9.5" would look all around.
    Mountain Tested----'03 zetec
    ZX3 vs MNTN - 15-2 & ZX3 vs TRACK - 23/1 JCM Racing #88
    Vacuum Vulture Racing - We Make You Less Powerless
    Quote Originally Posted by norcalfocus01 View Post
    ...too short to be a dick.
  8. #8
    Aug 2000
    Lincoln Park, MI
    13,945
    Once again, i'd like to point out;
    If Omni can put 275's on a Focus'
    305mm bare minimum on a factory 'heavy' fender flare RWD V8 is the only thing that can be considered.
    ///type dRew
  9. #9
    Aug 2000
    Lincoln Park, MI
    13,945
    http://farm3.static.flickr.com/2086/...0b95e9d0_b.jpg
    18x10 on 295.
    I want to see 1 more inch of wheel and more tire.
    ///type dRew
  10. #10
    Mar 2002
    Fresno, CA
    16,227
    Just the kind of input I was looking for (other than FOK, ) *I'm just looking for a euro-cruiser look, not an american-muscle look.
    I love stagger, but square of course makes life easier.
    275/40/18 on a 9.5" wide wheel would look delicious I do believe, with just a mild 1" drop all around
  11. #11
    Mar 2002
    Fresno, CA
    16,227
    BTW... there has been not one response on the G8 board yet.
  12. #12
    Aug 2000
    Lincoln Park, MI
    13,945
    Hey, just being real.
    ///type dRew
  13. #13
    Jun 2004
    Drought ridden CA
    2,857
    You'd have to check fitment running 275's up front. An Agressive offset wheel would most likely rub a dub dub.
  14. #14
    Sep 2004
    Traffic
    11,368
    Quote Originally Posted by focusownerskid
    Omni put 275's on a focus with thousands of dollars of modifications to maximize performance. Not exactly what Hale is looking for. But, you are probably right. A 305 with the proper offset may fit under factory fenders. A 305 needs more than 9.5" wheel which the OP was asking about. Cost of wheels and replacement tires goes up SIGNIFICANTLY at that size.
    Quote Originally Posted by BOWERSdaAZIAN
    I will be checking fitment You can fit a small child between the tire and the inner fender as it sits now.
  15. #15
    Mar 2002
    Fresno, CA
    16,227
    Quote Originally Posted by brads03zx3
    All of that info is exactly correct.
    Not either of my children.
    I appreciate your input for sure Brad (and everyone else... even Drewski )
