Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > The Tire Rack Tires/Wheels/Brakes Forum
Sponsored by: The Tire Rack
Old 04-01-2009, 08:41 AM   #1 (permalink)
Default ST220 Wheels on ST170
The calipers from a MK3 mondeo are the same as the ST170 ones so am i right in saying that the hubs are similar? Is it at all possible to swap from 4 stud hubs to 5 stud hubs so that i can fit the mondeo factory fit 18" rims to my ST170
This is my first post here from sunny england so be gentle
Sp3no is offline
Old 04-01-2009, 10:42 AM   #2 (permalink)
MrBirdman330's Avatar
Default Re: ST220 Wheels on ST170
It is, but the width and the rim offsets are different be forewarned.
Everybody says you can't make money off small cars. Well, you'd better damn well figure out how to make money, because that's where the world is going. - Alan Mulally
MrBirdman330 is online now
Old 04-01-2009, 11:25 AM   #3 (permalink)
Chicks Dig Rodeo Clowns
bigdaddyzx3's Avatar
They are EXACTLY the same dimensions and offset as the SVT rims.
I have them on my ZX3
Regarding the Fiat 500 Abarth:
Originally Posted by S. on Da 5 View Post
That is a chick car. :D
Originally Posted by OmniFocus View Post
Well, I guess I'd better stock on bras and panties, because I'd drive the hell outta that car. :thumbup:
bigdaddyzx3 is offline
Old 04-01-2009, 12:04 PM   #4 (permalink)
How did you get over the 5 stud issue, the diamond cut ST220 18's are 5 stud, thanks for you help its much appreciated
Sp3no is offline
Old 04-01-2009, 12:06 PM   #5 (permalink)
DOH! Sorry, misread (not enough coffee yet)!!!
I have the ST200s... sorry I got your hopes up.
Old 04-01-2009, 12:08 PM   #6 (permalink)
Haha no worries
This is the rim in question
Sp3no is offline
Old 04-01-2009, 03:09 PM   #7 (permalink)
The Spindles should be the same diameter for both the four and five lug hub. Heres a couple pics of my five lug hub. Please excuse the quality, I need to buy a camera since mine is busted.
Old 04-01-2009, 03:41 PM   #8 (permalink)
Black EAPs = Love.
ZX3TUNING's Avatar
did you press the bearing on already?
how are you going to get that installed without destroying the bearing or is it a "slip fit"?
so the 5bolt hubs are the same spline count, shape and size? the OD on the bearing surface of the hub neck is the same? the length of the neck on the hub is the same? the overall bearing size is the same?
what about the rear?
links? pics?
if the rears are not the same then this is really useless as what good is the fronts fitting if the rears still dont!?
Power in Style.... ZX3Tuning
Part of Conglomerate Motorwerks!
Mitch A.
ZX3TUNING is offline
Old 04-01-2009, 03:55 PM   #9 (permalink)
I never did the conversion, but the hub came already pressed and ready to go. I don't know about the spline count I never made it that far in, I've been working on the research for those that want to do this conversion as a contribution to the boards. Talk to Trevor at fordpartsuk.com tell him Nathan sent you, or hit up your ford dealer to take a look at a five lug hub and Focus spindle. I'm assuming the spindles are identicle. But it might be on the safe side to order spindles as well. When you order the hubs they come pressed with the bearings.
Old 04-02-2009, 07:13 AM   #10 (permalink)
Has the mondeo got the 6 speed box that the ST170 has? Because i know ST170's have different driveshafts as the input into the gear box is unique to that box, not sure on the outer spindle though?
Sp3no is offline
Old 04-04-2009, 07:40 PM   #11 (permalink)
Black EAPs = Love.
ZX3TUNING's Avatar
i'm confused here... you've been working on the research but you have neglected the spline count and the are assuming the knuckle(not a spindle, sorry) are identical?
lol.... you might want to get a little deeper into the research before you post about it working or not.
the spline count, shape and size, the OD on the hub bearing surface, the bearing size and number, the length of the hub neck are all EXTREMELY important specs to have before you even consider a swap like this or you could just be throwing away money.
those would be the first area's i'd be researching if i was planning on doing this swap. And i certainly wouldn't be ordering parts without knowing at least approximate numbers on such things. if you are order parts from a dealer, it doesn't take much to get the parts guy to run in the back and slide the hub over a focus drive shaft rather than ordering and hoping for the best!?!
as far as the bearing coming pressed onto the hub already.... leads me to believe it's a different design knuckle(not a spindle, sorry)!
Mitch A.
Old 04-04-2009, 11:17 PM   #12 (permalink)
I said I'm still working on it but I'm working under the "Standardized Parts" theory right now.Which is why I'm under assumption the spindles are the same for either hub. When I get the time I'll be heading to the salvage yard since its a five minute drive to pick up more suspension parts to see how much is need for a full conversion. As opposed to driving thirty minutes to my nearest Ford Dealership. I'll probably head to a Mazda Dealership as well and look at the hubs and spindles on the Mazda 3.
Old 10-26-2009, 12:49 PM   #13 (permalink)
Any updates on this? Im interested in seeing where this can go.
Originally Posted by Maxximtl
He should have used fish net stockings to give his car that slutty "bang me off the rev-limiter" look.
Nickgt40 is offline
