Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > The Tire Rack Tires/Wheels/Brakes Forum
Sponsored by: The Tire Rack
Old 06-26-2009, 09:21 PM   #1 (permalink)
Default Extra parts for the SVT rear brakes, something I overlooked?
I installed the SVT rear brakes but there are some left parts I don't know what to do with them.
One of them is called "Control" part 5S4Z-2B384-AA that looks like a ring cap about 3 inches in diameter. There are 2 of them. The other parts are 4 bolts part W700672-S437. There are a bit oversized bolts. I see no use for them.
I installed using the instruction from Focus Racing. http://www.fordracingparts.com/downl...M-2300-ZX3.pdf
There is no mention about those parts. I got all other parts, though.
The car is still on the jack stands even though everything is installed save for the rust caps because I'm afraid if those parts, especially the control parts may be important.
2007 Liquid Grey Focus ZX5
FocusSport Stage 2 Turbo, Magnaflow 2.5" Exhaust, Eibach Sportline Springs, FRPP Dampers, Progress 22mm RSB, Steeda Tri-Ax STS, VF Rear Engine Mount, SVT Rear Brakes, Black EAPs
BoomBoy is offline
Old 06-26-2009, 09:53 PM   #2 (permalink)
FORDSVTPARTS's Avatar
Default Re: Extra parts for the SVT rear brakes, something I overlooked?
The 2B384's are the ABS tone rings so if you don't have ABS you don't need them.
As for the bolts? Not sure but if it's all bolted together then maybe there were extras by accident?
Edit- if you read the parts list on the first page of the instructions you'll see that those are the FRONT caliper bracket bolts so if you just did a rear install then once again you don't need them.
To order from me just call 1-800-328-9552 and ask for Steve or use one of the methods below.
2002 Silver SVT #2952 , custom CAI , Stage 2 throttle body, VF rear mount, FRPP 9mm wires, EAP/MACH HID's, Borla exhaust, K-W springs, FRPP UDP, Screamin Demon coil, Tuned by Mike at Unique Tuning in S.C.
FORDSVTPARTS is offline
Old 06-26-2009, 09:57 PM   #3 (permalink)
I have ABS. I installed the sensors. How are the rings attached? Between the rotor and the hub?
BoomBoy is offline
Old 06-26-2009, 10:04 PM   #4 (permalink)
They press on to the back of the hub, it can be done easily by just tapping them on gently with a rubber hammer.
If you didn't install them with the new hubs you're gong to have ABS lights on and no ABS working.
Look at the back of your old drums and you'll see them, they go on the new hubs the same way.
