Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > The Tire Rack Tires/Wheels/Brakes Forum
Sponsored by: The Tire Rack
Old 06-29-2009, 10:25 AM   #1 (permalink)
I pay 5 dollar!
Default rotated tires, bad vibration in steering wheel
I get a pretty good shake in the wheel now after rotating the tires. If the rear tire was off balance could I not tell as bad in the wheel until it was moved to the front? I feel it from about 25mph on up and back down from 60 to 25 or so as well.
Never really dealt with a balance issue before on my cars
this is on the 08 if it matters
2008 Focus coupe - current
2005 Focus ZX5 - gone, but not forgotten
"you could walk around with an overpriced slow Mac in a manila folder and be like "Yo, check this out, aww yeah, you didn't think there was a laptop inside but there was!!!""- Ducman
Focusfre4k is offline
Old 06-29-2009, 10:41 AM   #2 (permalink)
Administrator
focusownerskid's Avatar
Default Re: rotated tires, bad vibration in steering wheel
Your rears wore a bit and were thrown out of balance.
Get em balanced and you'll be alright.
2.3 L1QUID ZX3
///type dRew
focusownerskid is online now
Old 06-30-2009, 03:36 AM   #3 (permalink)
I pay 5 dollar!
yea I got them balanced and the vibration is gone, I still hear a humming/pulsing noise that goes the speed of the wheel. I thought warped rotor but I doubt it since I dont get pulsing in the wheel when decelerating from 65 . I will check again on the highway after work where its freshly paved and maybe take it back for them to look at...or try it under warrant if a part is going bad...we shall see!
Thanks for the reply!
Old 06-30-2009, 09:25 AM   #4 (permalink)
Administrator
It's most likely just the tire frequency.
Either get new tires, live w/ it or drive a bit faster/slower
2.3 L1QUID ZX3
///type dRew
Old 06-30-2009, 10:03 AM   #5 (permalink)
I pay 5 dollar!
I will take the car for a spin after work
nothing was as bad as warped rotors on the old focus though LOL
Old 07-01-2009, 10:35 PM   #6 (permalink)
How frequently do you rotate your tires?
2003 LG Focus ZX3 Premium Zetec 5spd
2006 Felt F3c
Auto_Focus is offline
Old 07-04-2009, 03:49 PM   #7 (permalink)
Ugh... I was plagued with the same issue when I first got my tires and balancing did nothing. I researched the web and there were other owners who had the same issue and their solution was to not rotate at all.
I got Tirerack to replace a pair of tires and the problem went away though.
Rear vibration goes to seats and floor. Front vibration manifests as shimmy as you're experiencing. Rear vibration is not nearly as annoying.
When you had your tires balanced, did you have them check the wheels for excessive run-outs? They can go out of round from poor workmanship by whoever installed your new tires, hitting pot holes hard or curbs.
Any panic stops that might have caused flat spots?
If all of those checks out alright, the tires may have non-uniform sidewall flexibility. They balance ok on a free-spin, but not remain in balance under load. The final line solution is to have all tires road-force balanced. It can be effective, but this is no guarantee and it's rather expensive. I believe it's around $80-100 for all four tires. Unlike regular balancing, they actually load the tires with rollers while balancing to simulate on-the-road conditions.
Some Schwabby locations have the roadforce balance machine. The one Barbur near PCC Sylvania has one.
xFOCIx is offline
