Sponsored by: The Tire Rack |
#26 (permalink) |
EDM Specialist
Yeah post #8 above.
2002 Liquid Grey ZX3 ··· SVT replica-in-progress 2003 Vermilion Red SVTf ··· ported JRSC BBK, ported head, 3" exhaust, Euro interior, more to come! strictly/focused • team edm |
#27 (permalink) |
^those are 18x8 and 18x9, i was talking about 17x8 and 17x9. my 17x8 TD 1.2's look significantly different then the 18x8.
Boost Camel Racing...when you don't care how rice you look in the name of speed :) |
#28 (permalink) |
EDM Specialist
I'm not talking about 17"s in this thread. LOL
17x9: http://img.photobucket.com/albums/v4...100_4043-1.jpg
#29 (permalink) |
Educating Mazda Owners One Thread at a Time
Fitment issues aside, I think you should consider what a change like that will do to your scrub radius, among other things...
"Darty" will probably be an understatement with low-offset 9" wide wheels on a Focus. ![]() You'll also be screwing with the rear geometry in a way that you might not think about right away...you'll effectively be lengthening the "moment arm" of the rear's passive rear steering setup, which could add some unsettling behavior to your car's handling dynamics. It's one thing to use these crazy wheel sizes/fitments to get "the look," but it's an entirely different thing to be attempting to put together a package with superior handling dynamics by using them. Food for thought, anyway.
Former: Modified Liquid Grey S2: 5-speed Modified 2001 White ZX3: 5-speed Current: 2008 MS3 GT w/ no options 2006 Suzuki SV650N |
#30 (permalink) | |
#31 (permalink) |
EDM Specialist
Yikes.... I even took the time to find a picture for you.
I thought it was clear I'm looking at 18's, that's all.
#32 (permalink) |
from the talk in the thread, and your posts it seemed to be about the fact you wanted to know if getting a 9 inch wide wheel was worth the trouble then a 8 inch wide for the sake of performance, seemed like weather it was a 17 or 18 wasnt so much of a big deal. But now its obvious it is. so good luck
Boost Camel Racing...when you don't care how rice you look in the name of speed :) Last edited by ClintB1321; 09-22-2009 at 04:24 PM. |
#33 (permalink) |
EDM Specialist
Sorry man... I guess I'm getting comfy with everyone on FJ. I'm not a prick in real life, I swear.
#34 (permalink) |
I am copying this from Canadian FS website...has lots of info for those doing RS conversion without actual RS powertrain. Pics are great for wheel/tire/suspension reference.
After long debate... Here is my Ford Focus RS Replica, it's a huge head turner. The colour changes throughout the day and its absolutely stunning. Always get compliment on the colour. The car handles great due to the added 3" of width and suspension components. The braking is out of this world. It's a great track car especially with the added gearing and limited-slip diff. Consisting of a 2001 Ford Focus ZX3 with 86000KM Ford Imperial Blue (Ford Racing blue) Full RS body. All original OEM lights + body trims (not the cheap wide body kit) 18" OZ RS Wheels Front 13" floating Alcon discs, 4 piston Alcon monoblock calipers Rear RS/SVT disc brakes. Hawk HP+ Pads Stainless braided brake lines. Sparco Torino 2 seats. 2" lowered suspension (spring and struts) Rear Sway bar Front and rear strut braces B post brace (for seat belts) Poly bushings all around. Torsen Limited Slip Diff Euro Gearing. Sach sports clutch Lightened flywheel Short shift Borla exhaust Poly Engine mount Most RS interior components (minus seats) Start button Brand new red top battery K&N air filter Sceaming Demon coil and Live Wires Priced at $10,000 OBO eMail me for more info @ xxxxxxxxxxxxx ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
For Sale or Lifetime Rent 2001 Pitch Black ZX3. Click Here For Details ! |
#35 (permalink) |
no prob, im not taking offense, i was just giving what i thought would be useful input but it doesnt work in conjunction with what your looking for, my bad
#36 (permalink) | ||
The difference in lip which you are referring to is based on the offset as well. If you want 8's have them make them in a lower offset to achieve the lip you want. |
#37 (permalink) |
EDM Specialist
It's not... it was confirmed with TDR that the lip is set by the wheel width, and the offset is done by shaving the hub of the wheel. They have a pretty big wheel design program though so I'm hoping they can custom make me an 8" wheel with the 9" face. Even the concavity of the spokes is different which I like better on the 9" version.
#38 (permalink) |
^^^ That is true with with certain manufacturers. Primarily with lower cost wheels.
I was referring to the Compomotive wheels and other higher end monoblock and multi-piece wheels. If you do end up going with a high end wheel, most companies can build you whatever you want. I had a set of the Compomotive MO 6-spokes in 18x8 and they had a decent 1" lip even with a 40mm offset. |
#39 (permalink) |
I'm bringing Zetec back...
stage3,
I was agreeing with him that a 18x8 10mm et wheels on a RS bodied ZX3 would have the same outer track width as a real RS. Not sure what you are asking.
Gerald 2001 MK fOCUS ZX3 Half aRSe 2001 B7 fOCUS ZX3 powerworks |
#40 (permalink) | |
EDM Specialist
Et16 is needed for an 18x8 on US hubs.
#41 (permalink) |
I thought it was determined earlier this year that the RS set-up is 1.25" wider per side. That equals 32mm, so 18x8 42mm + 32mm = 10mm. Where am I missing something?
#42 (permalink) |
EDM Specialist
I guess that's part of some of the confusion... normally track width is measured to the center of the wheel, but some of the RSOC guys in the UK seem to think the +65mm spec includes the extra width of the wheels, so actual track width might be smaller.
I don't know for sure, but I thought that was correct.
#43 (permalink) | |
Stoned Scorpion says, "GET OVER H.....OOhhh! Brownies!"
![]() ![]() I wish I had better pics to show you. I will gladly pull a wheel off and take pics of everything underneath. The only rubbing is from an old set of wheels/tires I had on my car (17x7 et40 215/45/17 on KW V1's) -spatakula
CAPS LOCK IS CRUISE CONTROL FOR COOL. |
#44 (permalink) |
Cayse, best thing you can do is finish your exterior and use your current wheels. After you fiddle with your coilovers, find a way to take some measurements where current wheels reside. Since you know current wheels dimensions [diameter, width and offset], apply empty space measurements to find what dimension you should go after. If it was me, I would do all this with fender removed so you can get clear view on all potential rubbing issues.
#45 (permalink) |
EDM Specialist
That's probably best, Davor... I just know I'm going to end up in a holding pattern for a few weeks though as the wheels get made at Team Dynamics.
#46 (permalink) |
Resident Wheel-Whore
I fit my 9 inch rears on the front and they fit...I never actually drove with them tho...
TUNED By FSWerks -- Parts by TOUSLEY Ford ~~BOOST CREW, Bottled Fresh since 2006 ~~ Vacuum Crew, Stirring things up since 2008~~ |
#47 (permalink) |
EDM Specialist
What offset, drop, diameter, tire size, got pics, etc?
#48 (permalink) |
They were the Schmidts I ran...the rears are 16x9. Just to see what they look like, I put them on the front. This was on my hatch with the coils wound all the way down...but like I said, I never actually drove with them on the front.
#49 (permalink) |
EDM Specialist
Bump... anyone have an 18x9 setup in the rear that they'd be willing to try mounting up front for testing?
#50 (permalink) | |
so you add an inch wider wheel on each side. would make up 1 inch total (giong further out) then you take it from a 49mm offset down. to a 16mm= 33mm 33mm =1.29" further out on each side. 2.6"+1 inch from the wider 8" wheel over the stock 7" (svt) 3.6"= 91mm or am i mistaken? i probably am wrong but thats how im seeing things.
Wings & Teeth ™ ("I'm U.S. with a little bit of U.K. swagger" ™ )
| Thread Tools | |
| Display Modes | |
