Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > The Tire Rack Tires/Wheels/Brakes Forum
Sponsored by: The Tire Rack
Old 11-07-2009, 12:52 PM   #176 (permalink)
Default Re: Nine inch wide wheels (widebody)... overkill?
Originally Posted by WRCwannabe View Post
i wouldnt be surprised if those wheels (svt mustang) weigh 30lbs.
I could live with that. I know the focus RS wheels are very heavy, don’t know the exact weight but even the Compomotive mo's weigh in at 26.4lbs per wheel and I can get the 4 mustang wheels and the hub conversion for the price of 1 compomotive wheel.
http://www.usacomp.com/Specs/MO/MO1880.htm
English is offline
Old 11-07-2009, 01:31 PM   #177 (permalink)
WRCwannabe's Avatar
yeah i know, those wheels are sick, id buy them, especially at those price you cant beat it.
but if you did a 5 bolt hub conversion, you open the door and have soooooo many options.
but those svt wheels are sick and well worth the money,/ where would you get the 5 bolt hub conversion at?
or would it be custom?
Wings & Teeth ™
("I'm U.S. with a little bit of U.K. swagger" ™ )
WRCwannabe is offline
Old 11-07-2009, 01:36 PM   #178 (permalink)
30lbs would be NO BUENO
Originally Posted by Terrible1 View Post
Mine is the same way with no noticeable difference in turning response. I absolutely hated having anything but factory toe settings :
haha yeah
Boost Camel Racing...when you don't care how rice you look in the name of speed :)
ClintB1321 is offline
Old 11-07-2009, 06:22 PM   #179 (permalink)
There are three options.
Custom hubs
Mazda 3 hubs or
ford mondeo hubs from europe, still looking into this option.
English is offline
Old 11-07-2009, 10:17 PM   #180 (permalink)
^^^ Will the Mazda 3 hubs simply swap over
might be worth looking into if it's that "simple"
Time Attack Unlimited FWD Class #26
SCCA E-Modified Class #26
Too many mods to list... Here is a link to my build thread http://forums.focaljet.com/team-rigz...6k-no-way.html
Terrible1 is offline
Old 11-07-2009, 10:35 PM   #181 (permalink)
Rears do. Front you need the knuckle of the mazda as well I think.
There a thread over on focusfanatics but cant find it at the moment.
found it
http://www.focusfanatics.com/forum/s...d.php?t=207451
English is offline
Old 11-08-2009, 11:29 AM   #182 (permalink)
EDM Specialist
CaysE's Avatar
You've gotta be f'ing kidding me... the '03 Cobra wheels were my backup idea.
I'm done... back to the drawing board. I'm not doing 9" wheels.
2002 Liquid Grey ZX3 ··· SVT replica-in-progress
2003 Vermilion Red SVTf ··· ported JRSC BBK, ported head, 3" exhaust, Euro interior, more to come!
strictly/
focused • team edm
CaysE is offline
Old 11-08-2009, 11:45 AM   #183 (permalink)
^why ru so discouraged to run 9's?
Old 11-08-2009, 12:06 PM   #184 (permalink)
LOL, sorry. Come on dont let me put you off from doing this.
English is offline
Old 11-08-2009, 12:32 PM   #185 (permalink)
EDM Specialist
CaysE's Avatar
It's no problem... my goal is to build something unique, so if someone else happens to have the same ideas as me before I can enact them, I'm just going to change mine.
I also considered 2000 Cobra R wheels in 18":
strictly/
focused • team edm
CaysE is offline
Old 11-08-2009, 01:41 PM   #186 (permalink)
That shot right there is so simple it's sick!
Originally Posted by Egz
I've always done it from the top. Its hard, but you just need a ratcheting wrench, and just feel for the nuts. Easier when its not hot.
sanzx360 is offline
Old 11-08-2009, 08:03 PM   #187 (permalink)
WRCwannabe's Avatar
tuck haha.
hood is my absolute favorite aesthetic mod on the car.
Wings & Teeth ™
Old 11-09-2009, 05:24 AM   #188 (permalink)
thenorm's Avatar
My example was theoretical... move the strut inward, and camber the wheel out to maintain contact patch. Naturally this means adjusting the strut separately from the wheel in some way.
this hit me with a bit of an eureka moment. there is a way to do this with crash bolt. granted most people would have used them just to add camber, but they could be used to camber out, and use proper camber plates to camber back in. this would move the scrub radius out abit. every littl bit helps.
edit: just did some math. assuming you can gain +0.5degree camber, this would move the scrub radius ~2.5mm outwards. maybe its not worth the hassle with teh crash bolts.
thenorm is offline
Old 11-09-2009, 11:43 AM   #189 (permalink)
EDM Specialist
CaysE's Avatar
The rears could be done by shimming the hubs at an angle... the caliper mounts are part of the hub so no problem there (then again, the rears aren't what matter). I suppose it could be possible to modify the front spindles with some cutting and welding with a similar result.
strictly/
focused • team edm
CaysE is offline
Old 11-09-2009, 01:05 PM   #190 (permalink)
[FJ] Addict
Um...Eureka! moment fail. The focus uses a pinch setup on the knuckle. Typical crash bolts will not work. And it isn't exactly the strut angle that matters with scrub radius (though on the focus it is very, very close to the steer axis). What creates the line for the steering axis is from the top of the strut to the ball joint. So, you could move the ball joint outwards (kinda hard with a cast knuckle, and the rotor being in the way, or pulling the top of the strut inward (like camber plates )
Now if you are talking about smaller diameter bolts for the lower control arm, again, what you are talking about would only reduce track width, and not change scrub radius. You would be effectively moving the ball joint outwards with the 'crash bolt', then moving the top of the strut outwards with camber plates.
And I'm not really sure what you are trying to accomplish here, but because the rear doesn't have a steering axis, it doesn't have a scrub radius. Shimming the hubs at an angle is a trick used by live axle circle track people to gain up to 1/2 degree of camber...unfortunately it is hell on bearings.
Mountain Tested----'03 zetec
ZX3 vs MNTN - 15-1 & ZX3 vs TRACK - 23/1 JCM Racing #88
Back to Dual Purpose Focusing
Vacuum Vulture Racing - We add stiffness
brads03zx3 is online now
Old 11-09-2009, 01:26 PM   #191 (permalink)
EDM Specialist
CaysE's Avatar
Originally Posted by brads03zx3 View Post
...And I'm not really sure what you are trying to accomplish here, but because the rear doesn't have a steering axis, it doesn't have a scrub radius. Shimming the hubs at an angle is a trick used by live axle circle track people to gain up to 1/2 degree of camber...unfortunately it is hell on bearings.
That's why I said it wouldn't matter on the rear ya mamaluke.
I'm talking about cutting the spindles and re-welding to change the strut angle.
strictly/
focused • team edm
CaysE is offline
Old 11-09-2009, 05:28 PM   #192 (permalink)
I wouldnt trust a set of cut and welded knuckles at all. Something as critical as the strut mount and how its a major part of the knuckle itself, is just asking for trouble if it were to fail.
Ingalls already make the rear camber shims if you were looking for them.
http://www.iapdirect.com/product.php...2&cat=0&page=1
stage3 is offline
Old 11-09-2009, 05:29 PM   #193 (permalink)
EDM Specialist
CaysE's Avatar
Come on man, I know you can weld anything.
strictly/
focused • team edm
CaysE is offline
Old 11-10-2009, 12:50 AM   #194 (permalink)
Sorry, I wouldnt wanna touch that job. I would use different knuckles and make them fit.
stage3 is offline
Old 11-10-2009, 08:22 AM   #195 (permalink)
EDM Specialist
CaysE's Avatar
I hear you... I think some Revo knuckle research is in order.
strictly/
focused • team edm
CaysE is offline
Old 11-11-2009, 06:49 PM   #196 (permalink)
CaysE Gerald REVSWIN had the idea of the Cobra R wheels in the back and SVT focus in the front.
jman89 is offline
Old 11-11-2009, 07:11 PM   #197 (permalink)
I'm bringing Zetec back...
REVSWIN's Avatar
This is true, been trying to locate a set of 17x8.5" 28mm et 2000 Cobra R's for over a year now. They have been discontinued for awhile now. You can find them in other sizes and offsets, but I had THAT size in mind. Just cant find a set with that offset anymore. All the places that have them listed on their websites, I called and they say "sorry they are discontinued".
You don't have to worry about me doing it though... I have since looked into other wheels. CCW at the top of my list.
Gerald
2001 MK fOCUS ZX3 Half aRSe
2001 B7 fOCUS ZX3 powerworks
REVSWIN is offline
