Sponsored by: The Tire Rack |
#26 (permalink) |
[FJ] Addict
Mike, you and Jeff are saying the same thing.
And I'm gonna come in and confuse some more. I do not believe the rear end toes in under compression. At stock height, the front most control arm, referred to as the toe link, is angled down towards the outside of the car. Under compression, this will swing the toe link outwards bending the control blade and forcing toe out. When I had my H&R race springs, this toe link was nearly level, so very little toe change occurred. I believed the 'passive rear steer-toe in under compression' stuff because that is what I read here. Once I looked myself, that is not the geometry I see. If somebody has a good reason to feel I am incorrect, PLEASE PM me and describe to me what is going on.
Mountain Tested----'03 zetec ZX3 vs MNTN - 15-1 & ZX3 vs TRACK - 23/1 JCM Racing #88 Back to Dual Purpose Focusing Vacuum Vulture Racing - We add stiffness |
#27 (permalink) | |
I am merely going off what I had read here or more accurately probably what I thought I read in regards to what the wheels do.
“Empty your mind, be formless, shapeless - like water. Now you put water into a cup, it becomes the cup, you put water into a bottle, it becomes the bottle, you put it in a teapot, it becomes the teapot. Now water can flow or it can crash. Be water, my friend.” - Bruce Lee |
#28 (permalink) | |
If I recall correctly, the original notion cam from a Ford engineer back when they were allowed to post on the board, but it was in no way an "official" post. From what I remember, we all thought the car had toe-out under compression and somebody came in to tell us differently. Since then it has been accepted as gospel. Curiously, I have a pending "upgrade" to swap my rear control arms. I could potentially plot the toe and camber curves at the same time.
Vacuum Vulture Racing: The masters of ape latexing. |
#29 (permalink) |
^let us know how that goes if you end up doing that
in regards to the toe link in the rear end, after i was told about the effects of it by the guys at HTP, brad and i discussed it and are under the same impression that at closer to stock ride heights, when the toe link is angle downward, the rear toe's out under load. but with lower static ride heights, which would place the toe link level, like on my application, toe change should be minimal
Boost Camel Racing...when you don't care how rice you look in the name of speed :) |
| Thread Tools | |
| Display Modes | |
