Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > The Tire Rack Tires/Wheels/Brakes Forum
Sponsored by: The Tire Rack
Old 10-21-2009, 09:32 AM   #1 (permalink)
Default bald rears AGAIN
So I posted last year right about this time with bald rear tires. Turned out that I needed to do an alignment after I put on the ProKit. Duh. Anyway, I bought new tires, did the alignment and everything seemed fine.
Fast forward another 16,000 miles (minus 8,000 miles worn on my winter tires) and I have bald rear tires again.
The winter tires showed almost zero wear, but the summer rears are once again completely bald. I took it back to the original alignment shop, who wants to charge me another $600 to realign it. However, I have verified that it is all still within spec (a second alignment shop).
Are the Yoko's junk? What's going on? I drive it pretty hard into corners sometimes, but that's about it. Wouldn't that wear the fronts too?
Eibach ProKit springs- 17"ASA AR1's- Yoko Parada Spec 2(summer)- stock 15" painted black with General Artimax Arctic(winter)-FS strut tower brace- Steeda Tri/Ax short throw- Brembo crossdrilled rotors- EBC redstuff pads- FS CoolFlo
2006pitchblackST is offline
Old 10-21-2009, 09:49 AM   #2 (permalink)
I pay 5 dollar!
Default Re: bald rears AGAIN
What exact model of tire? 16k on a high performance tire is not terrible depending on the model and how you drive it.
and wait....600 bucks for an alignment? LOL! 60 bucks max dude.
I do not see you mention rotating your tires? when was that last done?
2008 Focus coupe - current
2005 Focus ZX5 - gone, but not forgotten
"you could walk around with an overpriced slow Mac in a manila folder and be like "Yo, check this out, aww yeah, you didn't think there was a laptop inside but there was!!!""- Ducman
Focusfre4k is offline
Old 10-21-2009, 09:55 AM   #3 (permalink)
boostedzx3's Avatar
I have parada spec 2's and have run them since 2007 and probably have well over 15k on them and still 80% tread or better. Something seems off there.
Looking for a riding mower, snow thrower, push mower, weed wacker? Contact me, or email at
LNservices@ymail.com
Photoshop this euro kit and wheels on my car pleaz!
http://forums.focaljet.com/focus-con...it-my-car.html
boostedzx3 is offline
Old 10-21-2009, 10:11 AM   #4 (permalink)
Tarderator
aka: Red-SE-00'
$600 for an alignment means one of two things is happening...
1 - they have bent you over
2 - you did some serious damage to the rear and are just not coming out with it here
New Project coming soon...xB is stock again.
.2006 .Scion .xB .Polar White
Team Sun*Works
[FJ] focaljet - GUIDELINES - GALLERY - [FJ]WALLPAPER - STORE - SPONSORS - SEARCH - Any Questions?
syntheticGT is offline
Old 10-21-2009, 10:17 AM   #5 (permalink)
[FJ] Addict
Why is the shop trying to charge you $600? Why aren't you rotating your tires? Why are you using RedStuff pads?
Mountain Tested----'03 zetec
ZX3 vs MNTN - 15-1 & ZX3 vs TRACK - 23/1 JCM Racing #88
Back to Dual Purpose Focusing
Vacuum Vulture Racing - We add stiffness
brads03zx3 is online now
Old 10-21-2009, 10:26 AM   #6 (permalink)
all VERY good questions.
OE spec toe in in the rear will wear the tires a bit faster if you don't rotate them regularly.
“Empty your mind, be formless, shapeless - like water. Now you put water into a cup, it becomes the cup, you put water into a bottle, it becomes the bottle, you put it in a teapot, it becomes the teapot. Now water can flow or it can crash. Be water, my friend.” - Bruce Lee
sleeperlove is online now
Old 10-21-2009, 11:13 AM   #7 (permalink)
well i recently did an alignment cuz i bent my tie rods control arms and struts
after i replaced all those had an alignment done and it was like $30 so $600 is complete **** unless its absolutly perfect
rockin an 04 ford focus svt thats sonic blue with AEM cold air intake, CFM 67mm throttle body, BORLA cat back, FocusSport strut tower bar, msd coil pack and wires
also rockin a black 2000 zx3 thats stock except for the full obx exhaust catless with a fart can(came with the car bought it for 3k last time home on leave)
huskybruiserjr is offline
Old 10-21-2009, 12:27 PM   #8 (permalink)
bringler26's Avatar
I paid 80 for mine at the stealership man 600 is freaking crazy!
bringler26 is offline
Old 10-21-2009, 03:21 PM   #9 (permalink)
MrBirdman330's Avatar
80 at Goodyear for alignment but I have seemed to notice that ST's are a pain in the bottom to keep aligned I usually visit the alignment rack twice a year minimum once in the spring and once in the fall.
Everybody says you can't make money off small cars. Well, you'd better damn well figure out how to make money, because that's where the world is going. - Alan Mulally
MrBirdman330 is offline
Old 10-21-2009, 03:24 PM   #10 (permalink)
TolusD's Avatar
My 05 ST stays aligned for about 2000 miles then it starts to drift left.
TolusD is offline
Old 10-21-2009, 03:43 PM   #11 (permalink)
Mine lasts until I do a tire rotation then the issues begin with the drifting to the left. Then again I'm also having a problem with the left front rotor being slightly warped. I'm dreading the repair bill for that when I get enough money.
Old 10-21-2009, 04:39 PM   #12 (permalink)
bringler26's Avatar
I noticed after getting my tires rotated my car pulled to the left as well. Thats an interesting trend.
Old 10-21-2009, 04:47 PM   #13 (permalink)
[FJ] Addict
Unless I am changing my alignment, it has held fine. The only reason an alignment will slip is if fasteners are loose, there is slop in the bushings, or thing are bending (potholes, curbs, etc).
Old 10-21-2009, 04:47 PM   #14 (permalink)
The pulling to one side or another is likely due to the difference in wear patterns. It should go away once they even out a bit. The alignment doesn't suddenly go bad when you move the tires around
Old 10-21-2009, 05:00 PM   #15 (permalink)
x2
alignment affects the tires, the tires do not affect the alignment.
Old and Busted: 2002 Fully built Powerworks ZX3
New Hotness: 2004 Comp Orange JRSC SVT
As well as TWO 2002 Red SVT's
Parts by Karl @ Massive Speed System (www.massivespeedsystem.com)
Tuning and porting by Mark @ Skidmark Racing (turbof150.com)
venomrogue is offline
Old 10-22-2009, 09:39 AM   #16 (permalink)
I pay 5 dollar!
I agree 100%
When I had my 05 however, I could not get it aligned straight no matter the cost. Then again it was a total'd/reconstructed car LOL
Old 10-22-2009, 12:41 PM   #17 (permalink)
thenorm's Avatar
"within spec" is too broad. it can be within Ford spec but still eat tires., u need to tell them exactly what you want your car aligned to. tell them you want 0 toe in on the rear tires. that will most likely cure your wear problems.
thenorm is offline
Old 10-22-2009, 12:47 PM   #18 (permalink)
Originally Posted by thenorm View Post
"within spec" is too broad. it can be within Ford spec but still eat tires., u need to tell them exactly what you want your call aligned to. tell them you want 0 toe in on the rear tires. that will most likely cure your wear problems.
The only issue with going with 0 rear toe in the rear is that under panic braking the rear end is very unstable since as the rear suspension de compresses it toes the rear wheels out. Not something I would particularly want for a DD. Keeping that spec toe in in the rear is good for street stability.
Plenty of people have used the Ford spec toe in in the rear and with regular tire rotation have gotten perfectly even wear. You just need to not neglect rotating your tires.
Old 10-22-2009, 12:58 PM   #19 (permalink)
thenorm's Avatar
fair enough. put a little toe in if you are concerned about braking stability. but try to minimize it as much as possible.
Another thing to consider is that when you start loading the car with people and cargo, you gain toe in as the rear springs compress. So, setting toe to the 0 when on the alignment rack will have a little toe in when driving in real world conditions with people and things in the car.
Just before my big road trip this summer, i actually set some toe out, because i knew i would have a heavily loaded car for a lot of km (but i do toe adjustments in my driveway)
thenorm is offline
Old 10-22-2009, 07:05 PM   #20 (permalink)
GapBoyPCS's Avatar
My dealer charges only $120 for a four-wheel alignment. I have never had an issue with their settings, even after they adjusted to SVT spec once I installed the SVT suspension in my car.
I'm still lost on the $600 amount. Was that including all the stuff that needed to be replaced?
Was this car brand new (i.e. you bought the car right from the dealer new), or is the car used? It sounds like something is significantly off either in the settings or worn components -- assuming you don't get the same problems when your winter tires are on.
Richard - 2002 ZTS | Sangria Red | 434,000+ km...Be Bold, Stay Focused 24-7
Redline Rendezvous | OFOC - Ontario Focus Owners Club | SVTOA-Toronto
GapBoyPCS is offline
Old 10-22-2009, 07:50 PM   #21 (permalink)
Michael's Eye... Get It?
MichaelXi's Avatar
Nope.
After much study, it actually toes them IN to alter the "Slip Angle" when under compression.
0 Should be fine, but there's nothing wrong with going a HAIR to the toe'd IN side in the Rear.
Up front, How much Toe OUT I'd recommend depends on how much Negative Camber you're running.
MichaelXi is offline
Old 10-22-2009, 08:21 PM   #22 (permalink)
ZX3autoxtasy's Avatar
Guys, he hit an extra zero.
I think he meant $60.
2008 Specialized Tarmac:: 0.0mpg with more carbon than your Focus. Pure. Power.
2007 Ridley Crossbow: Beware. Terrorizing you town until I sell it for a TT bike.
2004 Pitch Black 5spd 2.0L(Z) ZX3: Eibach Pro-Kit Springs, Eibach Pro-Kit Dampers, Brembo Rotors, Hawk HPS Pads, H&R 24mm Rear Swaybar, P-51 Shims, Focus-Sport Cool-Flo, Focus-Sport front & rear stress bar, MBRP Cat-Back, [Track] 15'' Steelies with 205/50/15 Falken Azeni RT-615's,[Street]UK ST200 Mondeo Wheels w/ Toyo Proxes 4 215/45/17's, Quantum Audio 12''/Quantum 800w Amp, Custom Ported Box, SVT Lip, and tons of other stuff...
ZX3autoxtasy is offline
Old 10-22-2009, 08:47 PM   #23 (permalink)
Originally Posted by MichaelXi View Post
Nope.
I said toes out under DE compression Mike, I don't dispute that it toes IN under compression.
Also, I say from experience that 0 cause the rear to be unstable under heavy braking, its not a guess
Old 10-23-2009, 12:03 AM   #24 (permalink)
I've known alignment specialists to also do 0 camber on the rear wheels.
Old 10-23-2009, 01:14 AM   #25 (permalink)
MichaelXi's Avatar
I'm confused at what you're saying...
As I read it, you're saying two opposite things.
What am I missing?
