Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > The Tire Rack Tires/Wheels/Brakes Forum
Sponsored by: The Tire Rack
Old 11-01-2009, 11:39 AM   #1 (permalink)
Default SVT front brake pad fit
Went out to install the new OEM SVT pads on my 02 SVT and I've found that the new pads are just a little bit "narrower" than the originals. So they are too short to fit inside the grooves of the caliper bracket. Comparing them to the originals, the "hooks" at the ends of the backing plates seem to be about 2-3mm closer together on the new ones. Plus the overall thickness of the hook section seems to be bigger, such that only a serious amount of grinding is going to make them work.
Other than this, everything on the pad looks the same. What's up?
alexinRO is offline
Old 11-01-2009, 02:35 PM   #2 (permalink)
Default Re: SVT front brake pad fit
Take them back to where you got them and tell them you got the wrong pads. Take the ones you took off with to to show them what the problem is.
Anyone can go fast in a straight line.
2002 SVT Pitch Black #3633 ~ Built 7/2002
Tuned by Focus Sport/SCT ~ 17x7 White OZ Superleggera with BFG KDW 2's, street ~ 17x7 Dark Argent OZ Superleggera with Falken RT-615, track ~ Steeda Short Throw Shifter ~ VF-Engineering Rear Engine Mount ~ H&R Coilovers ~ Graphics by WebXtremes
McSVT is offline
