Sponsored by: The Tire Rack |
#1 (permalink) |
I'm headed out to a junk yard to scrounge an SVT rear brake set up. What tools will I need to do this? I don't want to load my whole tool box. Thanks!
2001 Sangria Red ZX3 |
#2 (permalink) |
sockets
03 Sangria Red zx5 stock :) 09 Harley Sporster 1200 :) 99 Yamaha R6 (stunter) :) 93 S10 -SBC in the works :) ._________________________ |.....Overnight.....................| || |........Japan Parts................||'|";,___. |_..._...____________======||_|_|...,] "(@)'(@)""'''''''''''''"'''"**|(@)(@)*****"(@) |
#3 (permalink) |
Resident Wheel-Whore
How long the SVT been sitting? Maybe a torch. Some kind of cutting tool...lol
TUNED By FSWerks -- Parts by TOUSLEY Ford ~~BOOST CREW, Bottled Fresh since 2006 ~~ Vacuum Crew, Stirring things up since 2008~~ |
#5 (permalink) |
I <3 UC^3
In Michigan? Definitely torch/demo saw. That stuff is going to be a bear to get off in the junkyard. Cut it apart and then take it home and do the parts you need right.
2001 Twilight Blue ZX3 - Volant Intake, FC 65mm TB, SVT Header, RT High Flow Cat, SVTF Borla Exhaust, Koni's 1985 Nimbus Grey Merkur XR4Ti - Work In Progress Tuned By: Bristol Dyno |
#6 (permalink) |
I'm bringing Zetec back...
Have you priced it out with Steve at Tousley? IMO it is worth getting all that stuff new.
You will also need a SVT or '02-up e-brake lever, as the the 00-01 e-brake does not hook up to the SVT e-brake lines. It has a different style hook.
Gerald 2001 MK fOCUS ZX3 Half aRSe 2001 B7 fOCUS ZX3 powerworks |
#7 (permalink) |
sockets, torch, pliers would be good... bring the pliers so you can disconnect the brake hoses, or just torch it all apart if you're replacing them anyway
Do you..... Focus? |
#8 (permalink) |
Got the rear brakes today. Channellocks and 1/2" drive 13mm. I got the dust shields as well. The exhaust looks very good. I'm going to try and get that too. Pulled the shifter and cables (already bought the Getrag) and I found the mass air housing just sitting in the car.
I've got my work cut out now!
| Thread Tools | |
| Display Modes | |
