Go Back   The Ford Focus Forum | Powered by Focaljet > Focaljet Premier Sponsors > Tousley Ford
Tousley Ford OEM Ford and Ford Racing parts at 10% over cost.
www.tousleyford.com
Old 10-27-2009, 07:10 PM   #1 (permalink)
Default Need a couple parts
Hey Steve,
I have a 2002 Focus SVT hatchback and I need to purchase the following...
2 license plate bulb housings (do these come with the metal connectors/hardware?)
PCV rubber/silicone hose 90* elbow
Thanks,
~Andy
'02 Infra-Red SVTF - 15.0 @ 93mph
SCT X3 by Randy @ FS | Magnaflow Cat-Back | CFM ORP+STS+Trans Mount+Billet Antenna | K&N SRI | MSD Coil+Wires | 65mm TB | FC UDP | VIS Invader CF Hood | Hella Dual Headlights
SVTsurfer is offline
Old 10-28-2009, 05:46 PM   #2 (permalink)
FORDSVTPARTS's Avatar
Default Re: Need a couple parts
Originally Posted by SVTsurfer View Post
Hey Steve,
Thanks,
~Andy
Lamps $4.91 each and they inlcude bulbs
PCV elbow/tube $15.39
I have both in stock.
To order from me just call 1-800-328-9552 and ask for Steve or use one of the methods below.
2002 Silver SVT #2952 , custom CAI , Stage 2 throttle body, VF rear mount, FRPP 9mm wires, EAP/MACH HID's, Borla exhaust, K-W springs, FRPP UDP, Screamin Demon coil, Tuned by Mike at Unique Tuning in S.C.
FORDSVTPARTS is offline
Old 10-30-2009, 08:55 AM   #3 (permalink)
Sounds great! I will give you a call today to place the order.
Is it easier for you guys if I place the order online or over the phone? I was trying to locate those items and I found the license plate lamps but I was unable to find the PCV elbow. Unless the PCV tube is called a "water inlet tube" in your system because that part is the only tube I could find with the same price as what you quoted me.
Old 10-30-2009, 10:40 AM   #4 (permalink)
Just give a call
Old 10-30-2009, 03:52 PM   #5 (permalink)
Thanks Steve!
