Hey Steve, need a few things priced
I need a new alternator, got an oil leak that's coated the current one and figure time to replace it when I fix the leak, I would also like to know which of the pulleys along the serp belt AND timing belt are available and their prices except the water pump pulley, crank pulley(replacing both with udp) and the timing belt tensioner(already have one). I am also looking for wheel bearings for the rear wheels, and stabilizer links for both fronts.
I also need a wiring harness for the Vehicle Speed Sensor.
Also if there are some other pieces I failed to mention but should be bundled with the alt or bearings, prices for adding those in as well.
Thanks
2001 Focus SE 5spd mods/SVT header cat & flex, FSWerks Stealth exhaust, FRPP 1.5" lowering springs
LinkBack URL
About LinkBacks
