James Barone Racing
Results 1 to 11 of 11
    Jan 2008
    Mill Valley/Diamond Bar, CA
    27
    Default Fuel filter location?
    I'm sort of ashamed to even need to ask this, but having never owned a fuel-injected vehicle before, I have only a really rough idea of where to look... Can anyone tell me where the fuel filter is located on a 2001 Focus ZX3? I'm confident that I can replace it myself, but I first need to find the darn thing. Thanks.
  2. #2
    Super Moderators GapBoyPCS's Avatar
    Oct 2001
    11,253
    Default Re: Fuel filter location?
    Welcome!
    No need to feel ashamed in the question. There is no doubt someone here is thinking the same thing.
    Here are some links that should help you on your way:
    http://www.myfordfocus.com/how-to/fuelfilter.htm
    http://forums.focaljet.com/team-tech...ht=fuel+filter
    EDIT: If you're new to the whole maintenance issue for a fuel-injected vehicle, it's also a great idea to pick up a Haynes or Chilton manual for some basic references, and have a healthy dose of FocalJet for the bits in between
    Richard
    2002 ZTS | Sangria Red |
  3. #3
    Jan 2008
    27
    Ah, I didn't even notice that the diagram on myFordFocus.com had arrows pointing to where the parts go. So it's just forward of the fuel tank, underneath the car? I'll get to it tomorrow, hopefully it fixes my problem and I don't have to replace the pump; I just got the car about three weeks ago. Today I was going uphill in 2nd gear, flooring it, and slowing down, pretty unnerving.
  4. #4
    Oct 2001
    11,253
    Unfortunately, it's a problem that quite a few have had.
    Since you're up, you may want to have a go at our Team Tech section. If you search that section, you will find many possible causes (such as clogged fuel filter, fuel pump, clogged injectors, etc.). Usually, people with fuel pump problems have their vehicles stall during hard cornering or driving.
    Now, the other question I have is are you the original owner? If so, you may want to find out whether you were part of an extended warranty that covered the fuel pump on selected 2000 and 2001 model years. That warranty was very specific in the vehicles it covered because it went on production date. That being said, the warranty only covers one replacement (so, if you have bought this car used and it already had a fuel pump replaced, then you'd be on the hook for the cost).
    My recommendation is if you're inclinded to do so, replace the fuel filter like you planned. After that, if you're still having problems, then start looking into the issue and/or get it checked out by a dealership or independent shop.
    And as always, ask away any questions you have.
    Richard
  5. #5
    Senior TEAM Member v8FociDreams's Avatar
    Jan 2007
    Carlsbad, CA
    1,668
    I changed my fuel filter a few months ago and when I did, I cleaned all the gas off the ends of it and tried to blow through it and couldnt even get air to go through it at all...was close to being clogged. Since then I hav e noticed approximately a 2 mpg gain and slightly better throttle response. FYI, Its kind of tight getting up in there to get the bolt off. I recommend a long extension to get up in there.
    Quote Originally Posted by LamarWH
    Is Dateline NBC even trying anymore? Must have been the new one.... "To Catch A Jackass"
  6. #6
    Jan 2008
    27
    Well, I replaced it, and on the short test drive I took (didn't have much room here to open it up) it pulled to 6k no problem!
    Had a little scare when after trying to prime the pump for a while, we disconnected the battery, and some little 18-gauge ground wire (black with brown stripe) broke off the negative terminal of the battery clamp. This allowed the car to go to accessory mode, but the odometer showed up as all dashes, the headlights wouldn't turn on, the wipers wouldn't move, and most importantly the car wouldn't start.
    It threw a couple DTC codes, 3918 and d262, which I guess are "battery too low" and some kind of anti-theft code, respectively. Hooked that thing back up and it sprang to life immediately. I'll get some pics tonight to show what I'm talking about, but I'm glad I'm back on the road. It feels like a totally different car. The stuff that came out of the old filter was naaasty; I'm kind of wanting to split it open to see what it looks like. Is there a date code or something on it? It's a Motorcraft filter, and I almost wouldn't be surprised if it's only the first or second filter it's had in 100k.
  7. #7
    Jan 2007
    Carlsbad, CA
    1,668
    Mine was the original filter. I bought the car with 34k on it a little over a year ago....finally changed it out near 80k in september.
  8. #8
    Feb 2003
    for sale forum
    5,141
    ahhh don't be ashamed dude, experience is something you dont get until just after u need it
    [FJ]
    check out my new project hit ALT + F4 to view the pics
    -There is a fine line between "HOBBY" and MENTAL ILLNESS"-
    [FJ] "more psi than your tires"[FJ]
  9. #9
    Jan 2008
    27
    Here's the wire I was talking about, don't worry because I plan on securing it more... Conventionally once I get access to a soldering iron.
    Also, what's the fastest way to pull out the foglights? I should get some fish for it
  10. #10
    I <3 UC^3
    Sep 2005
    Boston, MA
    12,861
    If you get under the front bumper, you should be able to see how that lower grill is attached and the foglights. Pop out the bulb connectors with a 1/4 turn and then remove the grill and fogs together.
    Joe
    2013 Oxford White ST
    1985 Nimbus Grey Merkur XR4Ti
  11. #11
    Ray
    Ray is offline
    Driver > Car
    Jul 2002
    CT
    24,001
    Contraband, if you look at the main battery ground to the fender there, you can put the ecu wire to that, just crimp on a ring terminal. I belive the bolt is an M6 x 1.00.
    I used to have a focus like you. Then I took an arrow to the knee.
    Intelligence is largely at the mercy of self-control
    Roadtrippin | CART | MCA
