FSWerks
Results 1 to 5 of 5
    TEAM Member djwrig04's Avatar
    Jul 2010
    crestwood, ky (or WKU)
    215
    Question e85 ethanol - will it work on a focus?
    with increasing gas prices, i was wondering if we can use ethanol in our 200-2004 focuses, slit port or zetec without ruining them or modifying them?
  2. #2
    WHERES MY KEYS?!? Redwake's Avatar
    Oct 2010
    Visalia, CA
    2,715
    Default Re: e85 ethanol - will it work on a focus?
    gas milage goes down when using e85... my k1500 was setup about the same as a tahoe i saw tested that wasn't flex fuel and they experianced a 25% loss in MPG durring testing.
    the price difference between e85 and unleaded wasn't enough for me to give it a shot but from what i heard flex fuel vehicles are setup to handle the gas as its can damage fuel lines etc... but in the above mentioned test it did not damage the vehicle it had the oposite effect and cleaned the engine.
    without mods it caused the engine to miss a little... a company in brazil makes a deal that you plug into your fuel injectors that delays them long enough to get rid of that miss. that was a $500 investment for that truck so i never went down that road.
    i haven't re-visted the idea of running e85 since.
    MK1 ZTS w/Lentec ATX - More economical than a Prius
    2" drop - projectors - boost by vortech - tune by fswerks
  3. #3
    Super Moderators GapBoyPCS's Avatar
    Oct 2001
    11,243
    I don't recall anything in the manual; however, the EPA, automakers, and other fuel/environmental groups have been locked in a debate and now lawsuit whether the EPA should certify E85 for vehicles between 2001 and 2006. There should be something from the EPA this month (January 2011).
    Richard
    2002 ZTS | Sangria Red |
  4. #4
    Jan 2011
    47
    From what I understand, bigger injectors, a brand new fuel pump (so that you do not mix the gas), and stainless fuel lines (e85 will eventually eat away the rubber ones) and it would work. This is more beneficial for higher HP cars. You do get less gas mileage with E85 and if you do the calculations for cheaper gas and less mpg, it does NOT make e85 worth it.
    However, as I said, on boosted cars it may be beneficial.
  5. #5
    Mar 2005
    Central MN
    58
    If saving money is your goal, E85 probably isn't the answer. As stated already, your mileage will drop by as much as 25%, not to mention the possile damage to your engine.
    IMO, the whole E85 thing is a scam. It costs more to produce than it is worth, hence the heavy gov't subsidies. It also produces more pollution to make it than it reduces by using it. Be nice to your engine and burn gasoline.
    Corn is for food, not fuel!
    (climbing down off my soapbox)
    2011 Sterling Grey SES...LOADED!
    2008 Dark Blue Pearl Metallic FX4
    2009 Vivid Black Heritage Softail
