Im not really sure where this should be, but I have a possible source for a SVT Zetec with the 6 speed transmission and everything that comes on the engine...computer, drive shafts and all. How hard of a swap would this be to do?
Thanks,
Justin
#1 |
Thanks, Justin |
#2 |
Administrator
How hard as in what? Time? Labor?
[img]images/icons/smile.gif[/img] If you can source all the parts needed, it should be plug and play. [img]graemlins/thumbup.gif[/img] - Drew |
#3 |
Hard as in labor I guess...how much work. I mean...all I need is the engine, ECU, drive shafts, all the accesories...right? I would probably just do a SVT Borla exhaust and SVT AEM intake. Would this be a good sleeper Drew?
Justin |
#4 |
Also...the SVT tranny and engine do not use different mounting points do they?
#5 |
You have to ask yourself this. Why do you want to invest so much time and money just to get a 170HP engine in your Focus?
#6 |
Because I can have the 170 hp and 6 speed tranny for around $1500......
#7 |
Dude, go for it. It's the same size and everything. I swapped a normal Zetec when my first one blew up and it didn't take long at all. I bet the driveshafts will take the longest, but I've never done them. The accessories are definitely plug and play. If you get that for $1500, do it! If not, lemme know how much the guy wants! [img]graemlins/evilgrin.gif[/img]
#8 |
can't wait to do the swap myself next month
#9 |
have you found a new engine yet?
#10 | |
#11 |
I'd get the engine but not the trans.
#12 | |
#13 |
Administrator
Justin - 3 Words.
Go for it. [img]graemlins/thumbup.gif[/img] - Drew |
#14 |
took it out the bottom as well... [img]graemlins/thumbup.gif[/img] looked much easier that way [img]images/icons/cool.gif[/img]
#15 |
1500?? let me know where i can get that.
#16 | |
Tell me how you can take a 130 hp. 5 speed to a 170 hp. 6 speed for 1500 bucks in parts via any other method? Usually I'd climb on my "swap it for the Duratec 2.3" soapbox....but not this time. [img]images/icons/smile.gif[/img] |
#17 | |
Location: 2.3L PZEV ENGINE TECHNOLOGY airforcefocus is still slooooowwww
Tell me how you can take a 130 hp. 5 speed to a 170 hp. 6 speed for 1500 bucks in parts via any other method? </font><hr /></blockquote><font size="2" face="Verdana, Arial">FS Race Header & Flex-$390 Bosal Cat Back- $265 Pro Flow-$140 Crower Stage II's - $290 FC TB- $165 AFX UDP-$55 Iceman Intake-$75 Early 2000 Intake Manifold-$180 FR Cam Gears-$0 STR Fuel Rail-$0 FC Water pump pulley-$0 total-$1500 Power- 180HP & 165 ft/lbs TQ any more questions? [img]graemlins/evilgrin.gif[/img] [img]graemlins/evilgrin.gif[/img] sorry had to.. [img]graemlins/lol.gif[/img] |
#18 |
whoops..didnt see the 6 speed part..yea Im an ass... [img]graemlins/lol.gif[/img] ohh well Ill take the 10HP more than 1 more gear...
but on a serious note..YES DO IT!! I would do that!! for $1500!! I would be like heelllll yesssss!!! that way you pave the way even more for us and engine swaps so we know whats ahead of us..Do it do it do it!! If you can ship me your old motor Ill make sure to dispose of it properly..thankksss |
#19 |
The six speed was the only reason, IMO. [img]images/icons/smile.gif[/img]
A five speed with good power and torque is hard to argue over. I bought an HKS cat-back then found out about these darn 2.3 Duratec's. I'm putting all my engine mods on hold 'till I can figure out what a complete swap will cost. I'm guessing I'd be ahead in the end. [size="1"][ 12-25-2002, 10:56 PM: Message edited by: Phillip ][/size] |
#20 |
the 2.3 is gonna be so badass...oh and that six speed not worth the time...slap that SVT up to the 5-speed...
#21 | |
#22 |
The thing you are probably going to run into trouble with is the PATS. If the cluster, wiring harness, PCM, & the Keys don't match each other then the car will not run.
Normally this would be an easy problem to overcome, but since the SVT Focus uses a different engine management system it poses a formidable task. -Mark |
| Thread Tools | |
| Display Modes | |
