James Barone Racing
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Like Tree2Likes
Thread: valve cover stuck!!!!
    Feb 2004
    Lake Geneva, WI
    311
    Default valve cover stuck!!!!
    ok, i need to take my valve cover off to paint it, and.... IT'S STUCK, i took off all the bolts on top and it won't budge... i need help asap so i can paint this thing. is there more hidden bolts or how do i knock it loose????
    after removing, do i need to buy new gaskets when i put it back on???
  2. #2
    [FJ] Specialist BowDown's Avatar
    Nov 2001
    NY State SUCKS!
    7,351
    Default Re: valve cover stuck!!!!
    I would suggest a new gasket.
    As long as all the outside and inside (spark plug area) bolts are removed, then take a rubber mallet and just tap on the corners. It will pop loose.
  3. #3
    Feb 2004
    Lake Geneva, WI
    311
    where can i get a new gasket? do i need one from ford or just an auto parts store?
    how hard can i smack it before it breaks? (i've been hitting it for a while)
    how much does a gasket cost?
  4. #4
    You Can't Make Me Laugh KonaZXIII's Avatar
    Oct 2001
    Orlando
    4,566
    Did you take spark plug wires out first?
  5. #5
    Jun 2003
    Weston, Florida
    2,368
    Just pry it alittle. Mine was stuck because of the gasket but I pryed around it alittle and knocked it loose.
  6. #6
    [FJ] Addict
    Apr 2002
    19,264
    do that only if you don't care about oil leaks
    just keep tapping with a rubber mallot. don't "pry" cuz our heads are made of aluminum which will score quite easily, leading to leaks like you wouldn't believe
  7. #7
    Apr 2003
    Morganton, NC
    2,572
    I don;t think you need a new gasket. I have used mine about 20 times. Just clean it well before reinstalling it.
  8. #8
    Oct 2003
    Maine
    1,758
    ditto
  9. #9
    Nov 2000
    VIR, CMP & points between
    6,176
    Or pry with a non-marring item. I found that a Bondo spreader fits in there and can break the seal without risking damage to either item.
  10. #10
    Jun 2003
    University of Missouri Rolla (UMR)
    440
    All you have to do is hit it a little bit with a brass hitter deal to cause it to break loose a little and it will come off... If not then go captain insano on it and be sure to get a new valvecover ...
  11. #11
    Feb 2004
    Lake Geneva, WI
    311
    yes i already had the plug wires out. i finally got it off. i'm paining it Anodized Blue, the two step rattle can process from walmart so hopefully it works. thanks everyone
  12. #12
    Sep 2001
    Fresno, CA
    314
    I had this exact same problem, work a wedge in between the head and the cover. I poped up enough to where I could pry it up without a problem. My valve cover does NOT leak.
  13. #13
    Feb 2004
    Lake Geneva, WI
    311
    i just beat it long and hard until it got off
  14. #14
    Senior TEAM Member Smoe's Avatar
    Dec 2000
    Little Rock AFB
    2,538
    Always has to be the pervert lol
  15. #15
    Feb 2004
    Lake Geneva, WI
    311
    ok, i was tightening the bolts to put it back on and it snapped it half, where can i get another bolt? will ford have one in stock or will a hardware store have one?
