Go Back   Focaljet - Ford Focus Forums > Ford Focus Performance > Zetec Tuning
Zetec Tuning Performance for the Zetec 2.0L powerplant.
Old 03-26-2005, 09:10 PM   #1
Decepticon_Zetec
Exclamation Basic Info & Problems: Tuning the Zetec
Welcome to Zetec Tuning...
Here are the specs on the Zetec. aka Zetec-E.
If there are any errors please PM me
Horsepower: 130hp @ 5300 rpm
Torque: 135tq @ 4500 rpm
Displacement: 121ci
Compression Ratio: 9.6/1
Cylinder Bore: 3.339
Crankshaft Stroke: 3.465
Connecting Rod Length: 5.3618/(97 5.4820)
Valve Diameters (Int/Exh): 1.260/1.100 (2 Int, 2 Exh)
Spark Plug gap "OEM": 0.051
Firing Order: 1-3-4-2
Throttle Body Diameter: 55mm
Redline @ 6750rpm
Governed speed @ 105mph
Coolant capacity: 6.1 quarts
Motor Oil capacity: 4.5 quarts
MTX fluid: 2.1 quarts
ATX fluid: 6.9 quarts
Installation & Parts coming soon!!!
If your looking to buy new parts for your focus.
Please look at our sponsor list.
Please show your support, and try here first.
http://www.focaljet.com/allsite/content/sponsors.html
Here are some basic problems that can occur with adding
bolt-ons for our cars. These can hinder the performance from
our mods.
Dirty MAFs
Your MAFs is located on your intake:
The two screws are a torx T-20 security bit.
When you remove it be very gentle with it. Do NOT touch the
wires inside with anything, i used some CRC electronic
cleaner you can pick this up at a local checkers..etc.
Vacuum leak:
when your hose becomes old, it gets sticky and
is very squishy. check to see if the hose has
any kinks in it. It comes around from behind the
engine and goes into a fitting for the PCV.
DPFE:
When this goes out, your car could bog down under load
and have a rough idle.
PCV:
When this sticks shut/open it could have some problems
with a lack or hesitation of power. but this may not
show signs of problems just by itself
TPS:
When your TPS seems to be acting up, your idle
could fluctuate up and down. people say to remove it
and start your car if it runs better, problem found.
Where are they located?
Maf = on your intake. MAF
TPS = side of throttle body. TPS
PCV = next to the header just look down and to the right. PCV
Vacuum = behind engine on intake manifold "larger hose". Vacuum
DPFE = on firewall left of brake booster. DPFE
What do good-bad plugs look like?.
Normal "good to go"
Worn Out "replace plugs"
Oil inside of Cylinder "rebuild time!"
If you can think of anything else that can wrong with adding
MORE power to our engine, without use of F/I, please PM me.
Thanks everyone.
Decepticon_Zetec
00 Powerstroke Crew cab long bed
05 Honda Accord
Decepticon_Zetec is online now   Reply With Quote
Old 07-10-2005, 02:39 AM   #2
Decepticon_Zetec
Default Re: Basic Info & Problems: Tuning the Zetec
Are you worried about your warranty when you have performance parts installed?
Read Here
And Here
Old 03-12-2008, 03:07 PM   #3
thor
Newbie
Displacement: 121ci
Redline @ 6750rpm
our mods.
Dirty MAFs
Vacuum leak:
DPFE:
PCV:
TPS:
Normal "good to go"
Thanks everyone.
Decepticon_Zetec
105 mph limited??? i have a 2003 zts i bought it used and it will do 120 before it shuts down...105 huh?
thor is offline   Reply With Quote
Old 03-13-2008, 09:27 AM   #4
slo_poke_blackzx3
I bet the previous owner did something to the ecu, either chip or re-flash. Mine actually shut down at 108 pre SCT chip.
slo_poke_blackzx3 is offline   Reply With Quote
Old 03-14-2008, 04:58 AM   #5
hansbiemond
Newbie
Question Re: Basic Info & Problems: Tuning the Zetec
If i can choose between a Zetec 2.0 litre engine and a Duratec 2.3 litre engine, witch should i take to reach the most power?
I'm a student from Holland and we're building kitcars at school, our goal is to get a lot of power in them.
hansbiemond is offline   Reply With Quote
Old 03-21-2008, 08:40 AM   #6
sleeperlove
Sleeper Cars Suck
Most definitely the 2.3 duratec. It has way more potential than the 2.0 zetec
Nurburgring times don't Matter
http://www.speedsportlife.com/2008/1...itter-porsche/
Originally Posted by Chalz
I love the smell of Jesus-justified hate in the morning.
sleeperlove is offline   Reply With Quote
Old 03-28-2008, 03:54 PM   #7
shbfd
Definitely 2.3 Duratec as the saying goes "No replacement for displacement".
shbfd is offline   Reply With Quote
Old 03-28-2008, 05:09 PM   #8
gobstopper
That's less important in this case than a great cylinder head and some decent rod length, but yeah.
fasfocus00 = Douche Canoe
gobstopper is offline   Reply With Quote
Old 04-01-2008, 08:04 PM   #9
myfafp3
Hmm I keep hearing about the ford ranger cranks. Are people making stroker motors with the ranger crank? Or am I imagining things? Sure sounds like a good idea though
myfafp3 is offline   Reply With Quote
Old 05-17-2008, 03:09 PM   #10
Bparks717
governed speed is 112 i know it make me angry
80 Firebird=sold (sadly)
89 240sx= project
02 focus zts= automatic (TRADED IN THANK GOODNESS)
00 Focus ZX3= euro sex beast in production
I live to praise my lord father Christ
Bparks717 is offline   Reply With Quote
Old 05-17-2008, 05:07 PM   #11
dougyfresh
hey i got a question i got a jackson racing throttle body and i just put it in and the car is not supercharged. when im at a dead stop and the light turns green and i shift into first and hit the gas i noticed that i have to rev up a little to get it to move or else it will stall out. is this normal?? i checked the screw and its fine and i also do i have to adjust the throttle cables/cruise cables or no.
dougyfresh is offline   Reply With Quote
Old 05-17-2008, 05:54 PM   #12
Omega Anomaly
dougyfresh: sounds like you may not have a good seal from the intake tube to the TB or from the TB to the intake manifold. You should't have to adjust the throttle cables.
Later
-Bryan
02.5 Infra Red ZX3, 115k+ on clock, Steeda suspension, Steeda Fuel Rail, MSS MSD90, MSS exhaust, FS Aluminum Flywheel, Exedy OEM Kit, Torsen LSD, Powerworks Supercharger
Omega Anomaly is offline   Reply With Quote
