So im totally confused as to what is happending, mabey you can help.
For some reason, the car @ WOT will not rev all the way out to 7500 rpms which is where I have MSD DIS II box set at.
Now this is what I have done so far, replaced plugs swaped back and forth couple times from AZFS-22C Motor crafts Now im with Denso Iridiums. Brand new coil pack.
Each time I try to rev out, itll rev limit, if you will, at eh 6800 rpms when I have MSD set at 7500.
Now, I did bypass MSD and it still will not alow the limiter I wish, My tuner has fuel cut @ 8K
Linear Mode
