Exedy
Go Back   Focaljet - Ford Focus Forums > Ford Focus Performance > Zetec Tuning
Zetec Tuning Performance for the Zetec 2.0L powerplant.
Old 07-04-2008, 04:29 PM   #1
punklife04
Default SVT Brakes on ZX3
Ok so I just bought all the hardware off an svtf and installed it on my zx3, all done except for two things
-I cannot get the clip on the caliper for nothing! any ideas would help out a lot!
-Also on the e-brake cables it's all together except for where it connects to to actual e-brake, can I buy that little piece from ford?
Justin
1999 Silver Frost Contour SVT
2001 CD Silver ZX3-borla cat-back-CAI-SVT 4 disc brakes
punklife04 is offline   Reply With Quote
Old 07-04-2008, 06:48 PM   #2
G-forces
Default Re: SVT Brakes on ZX3
Call Steve (aka, FORDSVTPARTS), if that part can be purchased from Ford, he will get it for you, and the price will be less than (usually) or equal to anyone else. He might also know the answer to your first question. Unfortunately, for calling any business, it's the 4th, you'll have to wait until Monday. Hopefully you can get the first part answered before then.
Stockholm Getaway: see it on Utube.
G-forces is offline   Reply With Quote
Old 07-04-2008, 08:37 PM   #3
grbrgrnzx5
I had a bit of trouble getting that clip on, myself. In the end, it took some pliers and screwdrivers and a bit of tapping with a mallet after trying it in about 5 different angles before I could get it to stay. I know it's frustrating, but be patient, and once you get it, you'll wonder why it took you so long to figure it out. BTW, that is a nice kit. You'll love it! I put that thing on my now-deceased Jellybean and WHAT A DIFFERENCE!
Lookin' fast in the slow lane
RIP, Jellybean (11/16/2001-6/16/2008)...you will be greatly missed.
2003 Infra Red ZX3 SVT-Totally stock...FOR NOW!
grbrgrnzx5 is offline   Reply With Quote
Old 07-05-2008, 09:50 AM   #4
G-forces
^Sorry to hear about "Jellybean". Was that the Focus with all the mods? I missed an "obit", did you post one somewhere... accident, or major mechanical failure?
Old 07-05-2008, 09:53 AM   #5
Juantron
It's ok, the Jellybean is being re-born piece by piece into my ZX5
2003 ZX5 TSCC Auto-X SM #30
Removed Whole Rear Interior, Relocated Battery To Back, Bomz CAI and Coilovers, UDP, MSD MSX90 Coil w/ Wires, KYB AGX Struts/Shocks, Bridgestone RE01Rs, Progress 22mm R-SwayBar, Hawk HPS Pads.
S2 Front lip and sideskirts, Hella Projectors.
Juantron is offline   Reply With Quote
Old 07-07-2008, 06:11 PM   #6
punklife04
alright I got the piece of crap in, now back to bleeding the brakes again, feeling a bit spongy
Old 07-07-2008, 11:18 PM   #7
punklife04
ok so new problem, I've bled the brakes multiple times (starting with pass rear, pass drive, front pass and front drive), and my brake pedal still goes close to the floor before it catches. any ideas?
Old 07-08-2008, 03:11 AM   #8
Liquid_02_ZX3
If you aren't getting any more air out of the calipers, bleed them from the lines at the master cylinder. Here is the process:
you need 2 people
have your helper sit in the car, attempt to slowly pump the pedal. With the pedal down half way and held steady crack the first master cylinder line just enough to get air or fluid. When your helper says pedal is on the floor have them hold it until you have the line tightened and repeat till you get no air. After all the master cylinder lines are bled, the calipers will need to be bled again. You obviously have air in your system and a lot of it.
Also if you are using a vacuum bleeder or pneumatic bleeder you can slightly tap the calipers with a wrench to help get any trapped air bubbles out.
'02 Liquid ZX3 Power Premium MTX
4-1 header, custom 2 1/2" flex and catback, CAI, custom Eibach Springs, KYB AGX's, painted 6 spokers, 225/50/ZR16's, B&M sts, Hurst knob, SVT cluster, Scangauge II, vac/boost & AFR gauges, 5% tint all arround, projectors with halo's, tail light covers, (2)12" Audiopipes w/3k watt amp, Jensen VM9512 headunit.
Liquid_02_ZX3 is offline   Reply With Quote
Old 07-09-2008, 06:06 PM   #9
punklife04
alright i'll give that a try in the next few days, just started a new job so harder to find the time.. but basically the same process as bleeding the calipers
