Re: Need Exhaust help!!
Depends on if you want your car emissions legal. Shorty would keep it legal, but the header bolted to stock exhaust would show little improvement. The longtube header would eliminate the cat and give you better gains; but, be extremely loud and not emissions friendly.
For a complete exhaust setup:
1.) Shorty route = Shorty Header, High-Flow Cat, Flex Pipe, and Cat-back exhaust
2.) Longtube = Longtube header, flex-pipe / off-road pipe, and cat-back exhaust
#2 is cheaper, more power potential, extremely loud and illegal in most states. #1 is more expensive, not as loud as #2, not as much power gain (maybe) and is legal.
I spent close to 1K on my shorty setup. Installation wasn't bad untill I hit the header. Be EXTREMELY careful when instyalling header bolts. Steel bolts > Aluminum head and will cross thread easily. I have to get head work done due to cross threading. I cross threaded a bolt by hand. No tools. End result is nice though.
Be sure to have all the tools you need to lower install times. If I had had everything I needed up front, my install time would have been a lot shorty.
My car seems to perform better thru entire power band and has a mean sound to it to. Wish I could get a sound clip up here. I'll have to figure something out when I get the car fixed.
Hope this info helps.
