I hope that by posting this thread it will not only be a learning experience for me but maybe others can use this info...
...I drive an '02 ZX5 Zetec. Mostly stock with a cold air intake. Two months ago my battery light came on so I had the system checked at the shop and we came to the conclusion that the diodes were bad in the alternator. Went ahead and changed out the alternator, which was a b**ch by the way. Once changed, everything was fine. Battery light off and I was back on the road. That was two months ago. Now here about a week ago, my battery light came on again and the car just stalled out and when I tried to start it back up, it acted like a dead battery.(No radio, no power, clicks from starter silonoid) Without second guessing the alternator I went and got a new battery. I got 30 seconds down the road and the battery light came back on. I got home and put the thing on a volt meter and with the car running, I got like twelve volts at the battery and dropping slowly. I figured the alternator was defective so I called the shop and had them send me another one and then I installed that one. The car started and I let it idle for twenty min and no battery light. YAY.....
.....UH oh, Im ten minutes down the road and woulnt you know it, Mr. Battery Light shows up again. I make it home but now my car is sitting in the garage as it has been for a week now. Starts with a jump but then only runs for about 2 min. by itself.
Symptoms:
-battery light on
-drains battery and then car dies
-once car dies, the guages lay flat and airbag light comes on
-weak start and turn over
-with car running the volt meter reads like 12 volts
-all fuses are good
The Goods:
-New alternator
-New battery
-All visual power and ground cables look good
I know this is a bit confusing and if anyone has a question or a comment or just some geniune help then please post here. Thank you JET!
Linear Mode
