Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > Zetec Tuning
Zetec Tuning Performance for the Zetec 2.0L powerplant.
Old 10-21-2009, 04:38 PM   #1 (permalink)
GrndZero's Avatar
Default Cleaning a Volant Air Filter
I would like to clean my Volant air filter. Would this be worth it or advisable or is buying a new one a better option. It has stayed clean for a long time but its over due time from the looks. I didnt want to just go buy a cheap replacement.
Ma Focus
GrndZero is offline
Old 10-21-2009, 10:06 PM   #2 (permalink)
I <3 UC^3
Default Re: Cleaning a Volant Air Filter
I cleaned mine with their kit. No problems.
Tuned By: Bristol Dyno
hEaT is offline
Old 10-22-2009, 07:51 AM   #3 (permalink)
GrndZero's Avatar
Ok, I will go that route. Its cheaper than buying a new one.
Ma Focus
GrndZero is offline
Old 10-22-2009, 03:01 PM   #4 (permalink)
trailbikerider's Avatar
I used a K&N kit, really anything will work. Just make sure when you use the cleaner spray, it's completely dry before you re-oil it.
170,000 miles and counting......[10/28/09]
Borla l Volant l SVT l FRPP l Massive l CFM l General Tire
trailbikerider is offline
Old 10-22-2009, 04:02 PM   #5 (permalink)
GrndZero's Avatar
So the blue stuff that comes with the volant kit doesnt really matter?
Ma Focus
GrndZero is offline
Old 10-31-2009, 12:32 AM   #6 (permalink)
No, it's just the certain color of oil they use.
Old 10-31-2009, 03:13 PM   #7 (permalink)
I got my Volant second-hand, and used the K&N kit to clean it every 10,000-20,000 miles. The filter still worked great after 100,000 miles of use.
Be very careful when you re-oil it to cover the filter thoroughly, but don't overdo the oil. I recommend letting the filter sit overnight to let the excess oil drip off. Otherwise, your MAF sensor may get fouled from the oil coming off the filter, causing your car to run like crap. It's easy enough to clean the MAF, but it's easier if you don't have to.
Flashing lights in your rearview mirror getting you down?? Stop being cop-bait! 8)
Zoomer69 is offline
