| Zetec Tuning Performance for the Zetec 2.0L powerplant. |
#1 (permalink) |
ok .... so i have changed the maf and still getting the same code. what would cause a low maf voltage? i have a fully built car with diablo mafia.. i have tried to remove the mafia and still will not start consistently. i dont know know what is wrong with my car. ihad this problem a while ago and dont know what i did that fixed it and now it is back? some help please...
#2 (permalink) |
More details would be helpful. What are you tuning with? Have you data logged the maf? What size maf tube? Injectors? Ect....
03 Zetec ATX E&S TURBO SYSTEMS powered sedan 00 Mustang Gt - Built motor - Soon to be Single turbo 07 Ninja 500R Building 640cc race motor. |
#4 (permalink) |
^Assuming he knows what he's doing, what's the point of having a MAFia?
I'm going to also have to ask if the MAFia is hooked up right? What voltage is low, Vref? (should be a constant 5V) |
#5 (permalink) |
i have not verified the maf voltage yet im gonna get out there tonight if i have time and check it.. and i thought there is only one way to hook up the mafia.. plus i am putting down over 400whp that is why we need the mafia...
#6 (permalink) |
If this is still the same issue you were battling before, it would be better to bump the old thread so people know what has been tried and discussed.
Best Regards, Randy Robles Vice President FocusSport / FSWerks www.focussport.com / www.fswerks.com 714.630.6353 ![]() Check out our NEW video on www.TheFordStory.com. Please leave a comment! Click me! The FocusSport Street Tuner Challenge Focus 396 WHP / 347 WTQ - Click me! |
#7 (permalink) |
Correct me if I'm wrong, but if you are programmed to use a MAFia, and are trying to start the car without it, it won't. I believe you need you have it installed in order for that program to mean anything to the car as there are translation factors involved in the programming when using those.
--UnFocused1-- AKA >>Matt<< --01 Focus "FCS-PWR" 350+whp Work-In-Progress-- <03 Ranger 4.0L "SKIGOD" DD: CAI, custom side exhaust, audio> >86 Ninja 250R "GOPED" 50+mpg bullet: Slip-ons, Pod filters, Jet kit, LED signals, custom plate bracket< |
#8 (permalink) |
im not sure... but i went out and checked the voltage and i had a constant 4.97v both before the mafia and after.. got the car started again but it died and threw another p0102 low maf voltage. im gonna try a different maf and see if that works..
it is a problem that i had before and i really dont know what i did to fix it before.. i think i just changed the maf... ill try it again.. |
#9 (permalink) |
often times when cars in general have a low voltage code on whatever 5v sensor you will find the sensor is unplugged or bad wiring...try un-plugging another sensor like the o2 or tps and see if a low voltage code pops up...if the car runs the same with the maf unplugged as it does plugged in it may have lost a wire and also use a datalogger or scanner to see if the maf has a signal reading or iat reading on the data list
best of luck
"he who says it cannot be done, should never interrupt the one who is doing it" R.I.P. RRE http://albums.phanfare.com/ofmphotos...ageID=45893499 |
#10 (permalink) | |
Doing so I found these 2, http://forums.focaljet.com/forced-in...f-voltage.html http://forums.focaljet.com/forced-in...-if-u-fix.html Really thinking this kid is in over his head . . . Back to this last MAF thread, Can you log MAF counts, G/sec? If you can that's all you'll be able to log. If you're looking for MAF voltage you'll have to manually probe the connector, ![]() D+ B- should read 5 volts F+ B- should be pretty stable, IAT voltage, will vary based on intake air temp, higher is hotter C+ B- should be MAFS count and I'm assuming the one you're looking for A+ B- should read battery voltage, 12 - 15 volts Assuming you're thinking that you should be able to log something like this --> http://www.dainst.com/info/maf/ford_mustang_maf.html That is no longer present in EEC-V, was in EEC-IV though. Basically it's just a name change but essentially the same thing. |
#13 (permalink) |
I'm dumb.
For sale: Eibach Pro-Kit springs, sedan taillight, lower grille, DPFE, EVR, MAFS, side markers, trunk handle, fuel door, gas pedal, headlight switch, AC/vent/defrost button, hazard switch, ashtray, silver console bezel, HVAC controls. 2004 infrared Focus SE Zetec ATX sedan "Ruby" CarDomain Page Last edited by Lancer211; 10-28-2009 at 12:41 AM. Reason: I'm dumb. |
#15 (permalink) | |
![]() I just facepalmed at myself.
For sale: Eibach Pro-Kit springs, sedan taillight, lower grille, DPFE, EVR, MAFS, side markers, trunk handle, fuel door, gas pedal, headlight switch, AC/vent/defrost button, hazard switch, ashtray, silver console bezel, HVAC controls. 2004 infrared Focus SE Zetec ATX sedan "Ruby" CarDomain Page |
#16 (permalink) | |
#17 (permalink) |
I don't have problems with the MAFia while data logging SVTs, but I'm looking at MAF volts. However, I can't recall using it on the Zetec and I would look at MAF counts on that engine.
#18 (permalink) | |
| Thread Tools | |
| Display Modes | |
