Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > Zetec Tuning
Zetec Tuning Performance for the Zetec 2.0L powerplant.
Old 11-06-2009, 02:36 AM   #1 (permalink)
Default Header/Exhaust system sound
I'm gonna buy this header
http://www.slickcar.com/productdetai...ProductID=7389
And I will also install the rest of the exhaust system, of course I can't afford a Flowmaster/Magnaflow cat back, so I'll put a custom system in a muffler shop (I live in Mexico), so my question is: What kind of system, diameter or whatever affects the sound should I install so my car won't sound a lot (like a ricer car)? I just want a nice sound, not so loud. I want a sound like this one:
http://www.youtube.com/watch?v=A6xhm...eature=related
THANKS.
antoniomontana0 is offline
Old 11-06-2009, 07:44 AM   #2 (permalink)
I <3 UC^3
Default Re: Header/Exhaust system sound
If you are deleting the cat, I'd go straight to a 4-2-1 long tube. Check out the OBX one.
It's a bit more expensive, but worth it.
http://cgi.ebay.com/ebaymotors/OBX-4...Q5fAccessories
For an exhaust, the biggest thing is throwing a huge resonator in there. That will keep it quiet.
Tuned By: Bristol Dyno
hEaT is offline
Old 11-06-2009, 09:25 AM   #3 (permalink)
Lancer211's Avatar
Go to 2.25"-2.5" exhaust tubing (57mm-63mm) and throw on a nice big resonator. You could also go the same route FocusSport went and throw on two resonators. The FS Stealth exhaust system uses two Magnaflow resonators.
That'll keep your header noise down.
Lancer211 is online now
Old 11-06-2009, 10:00 AM   #4 (permalink)
Lancer211's Avatar
Agreed. That link you posted isn't a 4-2-1 header, although they claim it is. It's a shorty header with an off-road pipe, which gives you the gain of eliminating the cat and smoothing out the exhaust flow, but to get a scavenging effect, you need a REAL 4-2-1 like the one that hEaT posted. The one you posted is crap.
Go with the OBX. It's an extra 5hp or so (at least) over the header you linked to.
Old 11-08-2009, 12:39 AM   #5 (permalink)
Thanks a bunch mates!
Old 11-08-2009, 04:16 PM   #6 (permalink)
G-forces's Avatar
It depends on how you want to drive the car. The shorty you posted will help preserve low end torque better that the long tube, but the long tube that is mentioned above will free up more top end HP.
If you use the shorty, stick with 2.25 inch piping, and a long resonator into a straight-through (turbo style) muffler. Bigger tubes will give a more hollow sound and slow your exhaust gasses. But you'll need to wrap the header, because it's chromed not ceramic coated, so the underhood temps will be high without wrap.
Stockholm Getaway: Escort Cosworth vs Supra... on YouTube. Don't try this at home.
(For some reason I thought this was a Focus the first time I saw it... now I have to find a new Signature.)
G-forces is offline
Old 11-09-2009, 01:38 PM   #7 (permalink)
mattellermets's Avatar
if you are worried about sound AND flow, you will want a high flow cat and as many mufflers as you can fit....
http://www.focusfanatics.com/forum/s...d.php?t=187791
SCT PRP FTMFW
mattellermets is offline
