Go Back   The Ford Focus Forum | Powered by Focaljet > Ford Focus Performance > Zetec Tuning
Zetec Tuning Performance for the Zetec 2.0L powerplant.
Old 11-06-2009, 08:07 PM   #1 (permalink)
Newbie
Cannonade's Avatar
Default Wiring problems
So I dont own this car yet but if i can find out whats wrong with it I might buy it off the guy who cant afford to get it fixed. The mechanic that was working on this car told me this.
Its a 2002 focus SE
The engine wont turn over and when you turn off the key and remove it the dash lights remain on untill you disconnect the power hold relay.
Not much time has been put into this car yet since the owner has no money to keep the mechanic on it. but heres whats been done so far.
Ignition switch, all fuses and relays out of both fuse panels all the engine sensors that draw constant power from the power hold relay have been disconnected and the PCM has been disconnected. The car does not put out a code.
I was wondering if you guys have any insight on this because if its something simple I might be able to pick this car up cheap since my current focus has limited tuning options.
I drive a 2000 ford focus with a 2.0 l dual overhead cam.
Cannonade is offline
Old 11-06-2009, 10:26 PM   #2 (permalink)
Default Re: Wiring problems
no clue on whats wrong with the car, but your last statement concerns me...how would an 02 SE which likely has the same motor as the focus you own have more tuning options?
01 ZX3. Ported TB, SVT header into RT cat to 2 1/4" OBX, VF Eng. top mounts, CFM lower mount, AEM CAI, CFM STS, Massive/FS strut bars, Massive UDP's, MSD coild w/Massive msx 80's, Centerforce Clutch, FS XCAL2, Comp Stg 3's not dialed in correctly cause I fail at basic math i guess?
Funktacular is offline
Old 11-07-2009, 12:15 AM   #3 (permalink)
Newbie
Cannonade's Avatar
mine is not a zetec motor =(
Old 11-08-2009, 12:39 AM   #4 (permalink)
i would guess it could be some wire problem by the ignition switch, i would get it if you can get it cheap becouse i dont think it could be anything serious
IS NOT WHAT YOU DRIVE, IS HOW YOU DRIVE IT
217 WHP 253 FTQ AT 10 psi = 13.8 IN A 1/4
MORE NEXT SEASON NEW SET UP IN THE WORKS
PRECISION TURBO KIT FOR SALE IN FOR SALE SECTION
lifer is offline
