Tire Rack 2
Results 1 to 14 of 14
    Newbie
    Dec 2007
    2
    Default 2002 ZX5 Timing Belt Replacement
    Hello,
    I have a 2002 Focus ZX5 with a stock 2.0 Zetec. The motor just turned over to 120k and I am planning to replace the timing belt and associated components. While making the parts list, I found a wide array of brand, prices and list of parts. So, I have a few questions:
    1) Which band of timing belt kit: Ford Motorcraft, Gates, ACDelco or Cloyes?
    2) Does this motor have one or two idlers? Kits are available with one or two.
    3) Which brand water pump: Ford Motorcraft, Gates, Bosch, ACDelco?
    4) According to the Haynes manual, it is necessary to loosen the cam-shaft pulleys. Why not simply set the engine to TDC and replace the belt?
    5) While in-there, I am considering replacing the aux belt tensioner. How long are these good for? I replaced the belt at 100k.
    6) Is it a good idea to replace the cooling system hoses while the cooling system is open?
    7) Is a puller needed to remove the crankshaft timing belt pulley?
    Thanks,
    Anthony
  2. #2
    [FJ] Addict brads03zx3's Avatar
    Sep 2004
    Traffic
    11,368
    Default Re: 2002 ZX5 Timing Belt Replacement
    1) I don't think it matters what brand you go with. I bought Motorcraft through Tousley Ford. They are a sponsor on FJ.
    2) One idler, and one tensioner (that does have an idler pulley)
    3) I went with Motorcraft through Tousley
    4) It is a good idea to reset cam timing when you replace the belt. Plus, with the pulleys loose, it is easier to get the belt on.
    5) It is a good idea to replace the serpentine tensioner at the same time
    6) I did. They start to get soft about 100k miles
    7) The name "crankshaft timing belt pulley" doesn't make a long of sense to me. There is a crankshaft timing belt sprocket, and a crankshaft serpentine belt pulley. You don't need to pull the sprocket, and no, you don't need a puller for the pulley. If you have an impact gun, that might help remove the bolt.
    A nice trick I learned, is with only the passenger side of the vehicle in the air and both tires on the vehicle, you can put the car in 3rd/4th/5th gear to rotate the engine slowly, or hold the engine still while removing the crank pulley bolt.
    I would also suggest replacing the thermostat while you have the coolant drained. Mine literally went bad 1 month after.
    Mountain Tested----'03 zetec
    ZX3 vs MNTN - 15-2 & ZX3 vs TRACK - 23/1 JCM Racing #88
    Vacuum Vulture Racing - We Make You Less Powerless
    Quote Originally Posted by norcalfocus01 View Post
    ...too short to be a dick.
  3. #3
    I <3 UC^3
    Sep 2005
    Boston, MA
    12,864
    You do not have to loosen the camshaft pulleys. I couldn't on mine. It's there so you can remove all slack from the front run of the belt. I turned my cam towards the front of the motor, put the belt on and then turned the cam back into TDC to tension the belt. It worked fine.
    Are you getting the special tools needed as well?
    TDC pin which is a M10 bolt 63.4mm in length and the cam bar which is a piece of flat stock EXACTLY 5mm thick, but 20-30mm in width and 180-230mm in length.
    Joe
    2013 Oxford White ST
    1985 Nimbus Grey Merkur XR4Ti
  4. #4
    Sep 2004
    Traffic
    11,368
    And I would bet $50 hEaT's cam timing is not so great. The factory cam timing on the zetecs was sporadic at best. Some were good, some were not. Mine was pretty good, but now I know that for sure. My previous roommate picked up ~5 ponies on the butt dyno and ~4 mpg after his cam timing was set to factory during the timing belt swap.
    Also, my car is a 2003, which seems to be the year Ford finally got most of the bugs worked out. My roommates car was older.
  5. #5
    I <3 UC^3
    Sep 2005
    Boston, MA
    12,864
    Quote Originally Posted by brads03zx3 View Post
    And why is that? I rotated the motor twice after doing it this way and the motor was still perfectly in time. I didn't over tension the belt with the cam and left all the slack on the tensioner side. Pulled the cam gear bar out and set the tensioner. Neither of the cams moved since I had the belt tension set right. If you are talking about the tools, they are the specs from the Haynes manual for the DIY-er. I've had the motor like this for 20k miles or so and it feels just as snappy as it always have. Car made 112whp and 120wtq when I only had the intake and exhaust so cam timing was pretty good from the factory.
    Joe
  6. #6
    Sep 2004
    Traffic
    11,368
    I don't have an issue with your tools. I used a metal file and wrapped it with electrical tape as it was just slightly too thin. I'm just saying it's not wise to trust the factory cam timing. I got lucky with my car, but while it is completely torn apart, it takes another 2 minutes to reset cam timing. Since you've had your car on the dyno you don't have much reason to doubt factory timing is too terrible.
  7. #7
    Aug 2006
    Connecticut
    1,086
    5 - It's prob a good ides to replace the serpentine belt idler pulley along with the tensioner at your milage level ... it's not an expensive item.
    02 sedan se (aka The SC'd se)
    Focussport/VF vortech intercooled currently @ 201 whp & 186 wtq on 93 octane
    Hey -- we don't know nothing about kids. So if you need something... Find it yourself. Or better yet, learn to do without.
  8. #8
    I <3 UC^3
    Sep 2005
    Boston, MA
    12,864
    Oh, I didn't trust the factory timing at all. I removed the old belt, set the cams at TDC and the motor at TDC using the tools and then put on the new belt.
    Joe
  9. #9
    Newbie
    Dec 2007
    2
    Thanks for all the helpful responses.
  10. #10
    Sep 2004
    Traffic
    11,368
    Quote Originally Posted by hEaT View Post
    I'm a bit confused...I understand you can put the engine and cams at TDC. But if you didn't loosen the cam sprockets, you didn't change the factory cam timing. And I couldn't get the belt over the sprockets with the tool holding the cams/sprockets in one place. It would have stretched the belt between the sprockets pulling them closer together when the tool is removed.
  11. #11
    I <3 UC^3
    Sep 2005
    Boston, MA
    12,864
    The cam gear in relation to the cam does not affect timing at all. It's the cam in relation to the motor. Think of the cam and cam gear as one piece. If the cams are set at TDC, they are at TDC. I could leave the gear alone or, loosen it, spin it around, tighten it back up and nothing would have changed in relation to timing. The only time it matters is if the gear slips after the belt is on because then the cam is not moving the same in relation to the motor and goes out of time.
    I couldn't get the belt on either. What I did was take the bar out and rotate the exhaust cam clockwise one tooth, put the belt on, put it back to TDC and put the bar in. That got the belt on and tensioned while putting everything back in time. I then got it over the intake cam and on the tensioner. I pulled out all the tools, turned the motor over a few times to set the belt tension and then put all the tools back in. I set the crank to TDC and the cam bar slid in with no issues so I knew everything was good.
    Before I removed the factory belt I checked the timing and the exhaust cam was a bit off. Now it's not.
    Joe
  12. #12
    Sep 2004
    Traffic
    11,368
    I understand what you are saying, but you have to be careful with your wording. You are right...if the engine is at TDC and the cams are at TDC, you can play with the gear all day long, throw it back on, throw on the belt, tighten it up and you're golden. BUT...if the cams are at TDC and there is slack or too much tension on the tension side, the cams WILL be displaced from TDC and cam timing will change.
    You got lucky. Once you removed the tool to locate the cam gear to the belt, you necessarily changed cam timing (engine was at TDC and cam was not). You know that, and we are saying the same thing. Once you spun the engine, put the crank at TDC, the tool slid right in and that very rarely happens, and hasn't happened on any timing belt replacement I've done.
  13. #13
    I <3 UC^3
    Sep 2005
    Boston, MA
    12,864
    Ah, I see what you're saying. Yeah, I did take it out of time on purpose and then got it back. I was lucky that I got it perfect, first try too.
    I wouldn't do it again this way if I didn't have to. I had a 1/2" breaker bar on the cam gear bolt and the longest wrench I had doubled up on the cam and I couldn't loosen the bolts. I stripped the torx splines on the bolt and it was the correct size bit too.
    Joe
  14. #14
    Sep 2004
    Traffic
    11,368
    That sucks. I didn't have the proper torx, so I tried it with an allen wrench and a long box end extension nasty sound when it popped loose, but it worked (don't try that at home kids).
