FJ Gear Store
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Like Tree3Likes
Thread: Fuel Pump Replacement
    Nov 2000
    VIR, CMP & points between
    6,176
    Default Fuel Pump Replacement
    I have a 2001 ZX3 that is in need of a new fuel pump. I noticed that a lot of the replacement parts reference a June 2001 build date. My car was built in Oct 2000.
    What are my pump options? I hear that the SVT pump is better and that the 04+ pump is good too. Are these a direct replacement? I don't need to support 400 hp, but I'd like to have the most reliable pump available as the car will be driven very hard.
    Thanks,
    Rich
    Racing cars are monsters that perpetually create work. - Peter Bryant
    Got kids? Get them involved in your car hobby and post about it here.
    My build thread.
  2. #2
    Kyle Gave Me His Oklahoma Foot Disease!
    Nov 2006
    Pissing off the Communists, CA
    11,270
    Default Re: Fuel Pump Replacement
    I believe you have to replace the entire tank when you change the style. I can check on that for you though.
    Maybe it's just easier to drop the tank as a whole.
    Quote Originally Posted by UrbanGypsy View Post
    Had a taste of Norcal in town last night, and you jerks all missed out.. Nick won the poker table, I sang some karaoke, we both drank and laughed, I got my face licked by a gorgeous girl, we ate street cart tacos, and I woke up with a bunch of assault rifles in my kitchen, then take a ride in the FSWerks coupe for coffee at the buttcrack of dawn. What a night!
  3. #3
    Nov 2000
    6,176
    Yeah, I cut an access hole so I could clean the strainer. Would be a major PITA to change the tank.
    Rich
    My build thread.
  4. #4
    Dec 2010
    Baytown, TX
    1,097
    Don't need to change the tank. You might need to slightly modify the housing. Supposedly it's pretty simple. Friend of mine has done his b4 and he did another friends svt. Took them maybe 45-60 mins to do. Some people(with no rear interior) have cut the sheet metal over the pump and made a simple access panel so they didn't need to drop the tank. Will be doing mine in the coming months. Steve at Tousley mention a recall replacement(maybe for the 2000 only?) And the 03-04 pump. Both in the $200+ range and need the "housing modified". Also supposedly the Ford GT pump will work as well and is only around $185. Have no idea what the modification entails but according to my friend its pretty easy. Of course he's really good with cars.
    2003 Twilight Blue ZX5
    Live knowing you'll die tomorrow
    Die knowing you'll live forever
  5. #5
    Nov 2000
    6,176
    I got mine out and it had a build date of 04 on it so maybe I had the recall done and just don't remember (I am the original owner). I went ahead and ordered the Bosch replacement pump. The pickup sock on my old one had disintegrated and I believe the pump ingested some of the parts. If I don't like the look of it, I might look for that GT pump.
    Thanks,
    Rich
    My build thread.
  6. #6
    Bacne..
    Apr 2001
    2,639
    Go to Ford and get the updated pump ... IIRC it's all they sell now. You can't go to a parts store and get the correct pump, all they have is the ****ty old stock housing.
    There are 3, I think, plastic tabs at the bottom of the tank that you'll have to cut off. Long utility knife and they cut through pretty easily. Then it's just dropping the pump in and wrestling with that damn green O-ring and big blue nut ... oh how I despise both those things!
    Far as I've ever found, the SVT pump is the same as the update pump. Both are somewhere in the mid 180-190 lph range.
    You know what your pump looks like so i don't have to post a pic of it, but the new pump will have a spring loaded tophat:
    (not actual pump)
    teamDFL likes this.
  7. #7
    Nov 2000
    6,176
    Thanks for the detailed response.
    I got a Bosch unit from Advance Auto, part number 67172. It has the Ford part numbers on it too and the procedure for removing the in-tank plastic clip, again with Ford part number on it, telling me that it is an updated part. It also has the spring top like the one shown above.
    (actual pump)
    Last edited by teamDFL; Dec 28, 2011 at 8:38 AM. Reason: Added part number of pump
    Rich
    My build thread.
  8. #8
    Bacne..
    Apr 2001
    2,639
    You'll be good then.
    The issue with the old pumps wasn't the actual pump but the design of the housing. The new housing has zero issues ... unless you're Givven and kink a fuel line
  9. #9
    TEAM Member cjheck's Avatar
    Jan 2012
    Toms River NJ
    216
    If you cut a hole in the floor can you post a pic please? I'm seeing if I should do this because I have an 01 foci which still has the original pump I'm almost sure. And FordFociSHO, when you say the design of the housing are you talking about the fuel tank?
  10. #10
    Senior TEAM Member CWCZX3's Avatar
    May 2001
    York, PA
    3,935
    Quote Originally Posted by cjheck View Post
    Check out my How-to post i just made on how i did this.
    Inkedfireman likes this.
    2000 Autumn Orange ZX3 "Beauty" Weekend Toy
    230hp 222tq@12psi 247hp 240tq@15psi Dyno Vids
    13.243@105.49 12psi June 06' Focus of the Month
    2013 Performance Blue ST Daily Driver
    2001 Flat Black ZX3 "Project River Rat" Sold
  11. #11
    Oct 2010
    Atlanta,GA
    17
    I have a 2000 4 door SE and mine died on me in the parking lot on new years eve.. However I was lucky enough to have bought the car with an extended warranty on it from carmax.. its covered so they are replacing it.. they mentioned something bout it needed to be dropped and something bout a new pump design. Also found 2 mounts shot on my eng. which is covered too.They ve had the car for a week and I just pay 50 bucks .. and I don't get frozen outside. Mentioned to me about recalls on my car from ford.. which I have to go have them do when I get it back. I m really glad they covered this cuase I didn't want to drop the tank out of my car on a set of jack stands..
    00 Blue SE Focus: Big 3 Grounding Kit, CAI, 2.5 Cat Back
  12. #12
    TEAM Member Inkedfireman's Avatar
    Dec 2005
    Woodstock, IL
    850
    Wait....so you don't get frozen....in Atlanta? LOL! Cry me a river! Just joking, any time you can get routine maintenance done the easy way, why not?
    '02 ZX3, currently down while I install the Garrett GT28RS!
  13. #13
    Rookie zx32nr's Avatar
    Oct 2009
    fall river ma
    26
    Default
    I would go to ford and see if they would replace it for free. I had an 01 and there was a recall for them. If you turn left or right to hard with less than a quarter tank of gas then it was part of the recall.
    Got mine replaced for free.
    Sent from my BlackBerry 9650 using Tapatalk
  14. #14
    Senior TEAM Member bflesher's Avatar
    Aug 2010
    Minnesota
    2,385
    Another reminder that I need to replace mine. <Sigh>
  15. #15
    Dec 2001
    SE Michigan
    844
    Quote Originally Posted by zx32nr View Post
    Just for the record, the fuel pump replacement program 3N01 actually wasn't a recall since it's not safety related. It was a 10 year, unlimited mileage owner satisfaction program that Ford intiated on their own to help keep their customers happy. There's a big difference between a recall (which is always safety or emission related) and an owner satisfaction program. Also, with recalls its a matter of coming in and having the work done no matter what, whereas with most owner satisfaction programs the repairs are only performed (at no charge!) if the specific symptoms are present.
