1 - 12 of 12 Posts
So, I thought this could be a beneficial read for those of you who crack/break your SVT sideskirts or get a bumper banged up. I'm using pics from an RS sideskirt I acquired that has been busted up at one end into 4 pieces.
As long as you have most of the bigger pieces when something actually breaks up (not just cracks) you can make do with some small gaps or chips missing. I was lucky that everything was there for this particular repair.
The first step is to remove all paint from the edges of where your going to stitch back together. Do the same on the back....having the plastic roughed up will help bonding. I like using a nylon abrasive wheel on a die-grinder because it doesn't destroy my fingers if I nip them while holding the parts. you also want to sort of bevel the top edge a bit to give more bonding surface for your urethane epoxy later.
Here's the pieces all prepped for repair, and the materials needed for this repair:
As you can see in the picture, I've purchased:
-Harbor Freight $15 plastic welding kit
-wide roll of 3M masking tape
-gel super glue
-instant set for super glue (bought at a hobby store, instantly dries/hardens/cures the glue so you don't have to hold for set)
-Bumper repair kit (not shown, consists of some wire screen, urethane epoxy, urethane body filler, and a spreader)
So, next step is to get all your broken bits into their homes and superglue them in place for now
I like to tape everything in place at this point just in case the glue isn't enough to hold it all in place while I'm working on the backside
Here you can see the back where I hit with they nylon abrasive wheel, and I've cleaned with prep-all
Time to plastic weld the seams. Start by getting both sides of the crack soft and almost melted, then introduce some of the filler stick supplied with the plastic welding kit. Work the mixture in a circular motion along the crack to stitch together
Will look similar to this when done
At this point, flip your part back over to the front side and use a dremel to bevel into your seams/cracks to prep for urethane epoxy
Clean with prep-all, and mix up some epoxy to fill your bevels. I like using fast-set becuase then I don't have to keep moving it around until it starts to set...as it is pretty "fluid" and will run.....but I'm experience and a novice might need the extra working time so use your discretion here.
Now, once the front has set up, flip it over and cut a piece of the mesh to encompass a little larger than the area you're repairing...this is to reinforce the repaired area (likely will become the strongest area of the part after your done). Mix up some more urethane epoxy and bond the screen to the back of your part.
once that's dry, back to the front. Start with some heavier grit paper like 220 and start roughing your shape back in by block-sanding
As you see, there's some shiny spots....those are your LOW areas....I use the sandpaper on my index finger and rough up the shiny spots so the filler has something to grab onto/bond.
now you can mix up and apply some urethane body filler. I tend to make a mess on this part, because I don't trust the spreader to get the filler really into the low spots so I wear gloves and smush it/swirl it around a lot and then I have a really ugly patch of sloppy filler to sand down.....but I usually only have to do one coat instead of sanding into an air pocket and needing a second coat so I consider it a trade-off.
Once very dry (try pressing a fingernail into the filler, if you leave an indent, it's not ready)...you can start sanding. As I said, I make quite a mess of the filler so I start with 80 grit to knock the heavy high spots down first and then go back in with 180, 220, and 320
now that you have your repair pretty smooth, it's time to spray with adhesion promoter and primer to see where you're at. I use black cause it shows EVERY imperfection.
at this point, it's close but needs a little more blending....from here I just blast with filler primer a few coats and let that dry about a day or two and then put a light light dusting of the black on it to block-sand again. when there's no more black specs in the filler primer, you're flat and done! No pics of that sorry, but from here it's just paint work....and that's a whole 'nother write-up!
this process can be used on any type of urethane/plastic part for your car.... cracked bumpers, sideskirts, lips, rear wing spoilers, etc.
Let me know if anything needs more clarification!
Awesome write up! I have some svt skirts that need some love. I'm not missing any pieces or anything but there's a lot of pretty deep pits from road debri or rocks or something... Suggestions on products for filling those up? They definitely require more than just sanding them out.
Discussion Starter #4
just find a urethane body filler.....sand first, clean, lay filler, sand, clean, filler-primmer.
this is very helpful. did you order everything online/ or just use your local auto store?
local auto-parts stores. For stuff like this I stick to carquest.
Nice write up.
I have some SVT sideskirts fully intact but one of the caps has a crack I want to repair b4 I put them on. Of course I'm not sure if I need/want to use the side clips since that would mean drilling holes. Was thinking of just bolting the ends in place and using 3M tape for the sides but not sure if that would hold well enough. Any suggestions as to mounting SVT sideskirts on a non SVT car?
Discussion Starter #6
Nice write up.
I'd probably substitute the 3M tape for just some RTV silicone, the tape will be too thin to catch the skirt in some spots and too thick in others.
Very nice write up! I can use this process to modify my center console to fit around my raised shift base.
Good idea as usual. The RTV should hold the sides perfectly. That way I don't have to try and drill a bunch of holes and worry about the lining up correctly. I could always drill the holes later if not happy with the RTV.
Discussion Starter #11
Sweet I can fix my cracked ST170 front bumper now. Any tips for a dimple on a plastic bumper?
dimples are hard....you can either get it hot with a heatgun and try to push it out, but even then it's going to need work. I usually drill a hole dead in the center and then countersink the backside of that hole....then scuff the heck out of the dimple and fill with urethane epoxy. then block smooth, little filler, sand, prime, paint.
Back from the dead! I sure want to try this. My SVT bumper would have been a great candidate but alas it was made worse in the accident and seemed irreparable. Unfortunately a dropped phone means I don't have a picture of it anymore. But COSVT wanted the bumper to repair for himself until he saw the pics so that was confirmation enough for me
1 - 12 of 12 Posts
