1 - 20 of 32 Posts
Item Description: Info Below
Price: $12346
This build is identical to FSWerks Black Sema Car that made 501whp with a 2871r. The Precision 5558 is bigger. The motor is solid. Starts up on the first turn. I have DRIVEN to Ford Nationals in Carlisle PA, 4 years back to back (500miles). The Built motor has 7,000 miles Trans has 5,000.
I will sell parts but not completely disassemble. I will ship items. I will not go out and get quotes and let you know. Most of these parts are large and heavy so it won’t be $20. (I shipped 4 Wheels and tires Via Fedex ~$200)
Would like to sell as following
-Motor : All Accessories Wiring harness PCM ect
-Turbo Kit : All items Directly related to Turbo Kit
-Transmission Trans, Axels and ect
Engine - $2,500
BUILT 2.0 Duratec
WPC Treatment on Full Rotating Assembly
Carillo Super A Rods
CP Pistons 9:1
Clevite H Bearings 77
Ported and Polished Head
Crower Springs and Retainers
ARP Head & Main Studs
Oil Return Welded to Oil pan
Turbo Kit - $3,000 (2008-2011 - will fit earlier models with Intercooler Pipe Adjustment)
FSWerks Turbo kit
FSWerks T3 Manifold (Ceramic Coated)
Precision 5558 CEA
Turbosmart 38mm WG
Turbosmart Dualport BOV/BPV
Siemens 80lb Injcetors (USCAR Connections)
3’’ Turbo Back Side Exit with External WG dump
3'' Intercooler
Transmission - $2,500
Level 10 BulletProof Transmission (rated to 350tq)
Upgraded Torque Converter
Valve body /w upgraded pistons
Suspension/Brakes
MotorSport Tech 4-5 Lug Adapters - $200
BAER rear brake kit - $400
VF Passenger and Driver Mount - $150 , $100
MassiveSpeed Rear Torque Mount - $100
I will check PMs
Discussion Starter · #2 ·
ttttt
Discussion Starter · #3 ·
tttt
Discussion Starter · #4 ·
yyyyy
Discussion Starter · #5 ·
ttttt
Discussion Starter · #6 ·
tttt
Discussion Starter · #7 ·
tttttt
Discussion Starter · #8 ·
ttttt
Discussion Starter · #9 ·
ttttt
Discussion Starter · #10 ·
ttttt
Discussion Starter · #11 ·
tttt
Discussion Starter · #12 ·
ttttt
Discussion Starter · #13 ·
ttttt
Discussion Starter · #14 ·
ttttt
Discussion Starter · #15 ·
ttttt
Discussion Starter · #16 ·
ttttt
Discussion Starter · #17 ·
tttt
Discussion Starter · #18 ·
ttttt
Discussion Starter · #19 ·
tttt
Discussion Starter · #20 ·
tttt
1 - 20 of 32 Posts
